Wireless Charger software update
KurtHu
Kurt
Seattle
2023 Azure Grey Wildtrak 4dr, 2014 Black JKURX
If you have a 2021 or 2022 and an iPhone 12 or 13 AND you have had this update from Ford TSB 22-2485 ("Wireless Accessory Charger Inoperative/Poor Performance With Magsafe Charging iPhones")...
Can you comment on if it made a difference?
rblock50
Ryan
Orange County, California
VW, Bronco
Would this be an over air update or something we need to go to the dealership for?
KurtHu
KurtHu
Kurt
Seattle
From the TSB: "Reprogram the WACM using the latest software level of the Ford Diagnostic and Repair System (FDRS)." Sounds like you need to take it to the dealer.
FleshTuxedo
A
PA
'22 OBX 2dr.
Following
rtaylor
R
ID
19Raptor, 22Bronco
The WACM software update on MY22 didn't seem to make any difference for iPhone 14 pro. The phone will charge fine when centered on the pad, but spotty if not centered. I also updated the software for passenger and driver doors, the instrument panel, and chassis. I had previously updated the driveline, ABS (traction control switch fix), and steering (severe duty upgrade). DIY with FDRS software.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
I’ve read for the past two years of issues of heat and disconnecting on the 21 and 22 Broncos, my 23 has never had any issues with my iPhone 14pro. I wonder if that was a hardware fix or maybe it had this software fix?
Rubicon 2 Badlands
San Ramon, CA
2008 JKU Rubicon / 2021 Bronco: Badlands/Sasquatch
The wireless charger in my 2021 Badlands is pretty useless. I don't even use it anymore. I'll have to see about the update. Thanks
Biz
Biz
Canada
21 OBX 2dr / 2019 Edge St / 2016 Focus RS
An update that works would be great.
Mine got my iPhone 12 and 14 pro so hot I did the $20 amazon fix which actually works great.
Ford Bronco Wireless Charger software update IMG_0260
rblock50
Ryan
VW, Bronco
How fast does that puck charge? I’ve found that only the OEM Apple ones charge at full power, all of the other ones I’ve tried are slower. I don’t know why that it, somehow they’ve got a monopoly on 15W charging?
Also, what is that thing plugged into your USB?
Baerkeeper
Los Angeles
2023 2dr Basequatch | 2020 Miata RF
Does it fast charge?
JohnnyBronco
Pennsylania
X4
So now your tie rod ends are beefier just from a software update? Sweet.
X JBM X
boston
wildtrak
I did something very similar. The phone charges quicker for sure, and i know that it's in the right spot with the magsafe puck. Think I paid like $14 for the charger.
ne2000
Nathan
St. Louis
www.instagram.com
Bronco, Mustang GT
Biz
Biz
Canada
Yes and charges it to full.
I searched 15W usb C and a few came up. I tried to get the threekey one off amazon but it was always sold out so I found this one.
(kkm 15watt)
Works great. The magsafe holds the phone and centers it. A bit of 2 way tape and it solved a very annoying problem.
Its a USB light. You can change the colors. I have an outer banks and have switched grab handles so mine are blue to match the door panels.
