- Jaime
- Jul 13, 2020
- 6
- 326
- 394
- Clovis, CA
- 2020 Camry TRD
- First Edition
The grill was easy to take off, mostly just plastic retaining clips (inside engine compartment) that are super easy to remove with a super small flat screwdriver and an Automotive Door Panel Plastic Fastener Clip Removal Tool. The hard part is prying the grill out from each side without scratching the vehicle's front fender paint. Get some practice of removing the fender flares after unlocking the speed clips a quarter turn to the left and you will get a feel of the pressure that it takes to pull apart the grill.Hey, I just received my Xpel Headlight kit, so hoping to apply them to the headlights in the next several days. So you took off the grill for better access to the headlights during installation, correct. Per Youtube, it looks like grill removal is easy, correct? Also, do you have stock driving/fog lights, and if so, did you get PPF covers for them? My Big Bend does, but I haven't located PPF kits.
After that, you should do a decontamination stage to the headlights.
1- Wash Headlight
2-Dry headlight w/ microfiber towel
3- Spray Iron remover (Autoparts store) on headlight with towel catching the product dripping (Adams Polishes) has instructions on the website on use and removal.
4- Use an exterior detail spray to wipe off (Iron Remover from Adams instructions)
5- Clay bar headlight use detail spray to help glide the clay across surface
6- For Headlights that are fairly new like our bronco I would skip the mechanical buffing/polishing stage to keep the surface protection from the factory intact.
7- Use Adam's Surface Prep or make your own prep solution (70% iso Alcohol) mixed at a 1/3 ratio with "Distilled Water" in a spray bottle on the headlight to strip any waxes, oil, chemicals.
8- Use a slip solution (mix a couple of drops of baby shampoo with distilled water) refer to youtube video for mix ratio suggestions. and spray liberally on the headlight and then on the PPF adhesive side first and then on the non-adhesive side.
9- Lay the PPF over the headlight paying close attention to the line cut out in the PPF making sure that its lines are straight and positioned as best as possible using the blinker light as the most critical area to position it correctly and professionally.
10- For the rest please watch Youtube videos to get a better understanding before attempting any PPF install.
11- I have attached a photo of my Bronco Headling without grill so you can see the amount of space that it opens up for you and also the lines in the PPF if you have the Signature lights that is key in making sure is set right.
