- Chris
- Jul 11, 2020
- 0
- 345
- 790
- Austin, TX
- Subaru BRZ
- Badlands
I do have Sasquatch. I'm fine with your odds are better going 4-door. But I was told verbatim I would not be eligible unless I switched to a 4-door.It's true if your current order is a base 2-door without lux/sas. Because in that case, you have nothing to drop, to be eligible for the $2500.
Also, even if you do have lux/sas to drop from the 2-door, while you can then be eligible for the $2500, I suspect that is a losing bet. Realistically that 2-door will not get delivered in 2023, and you won't get that $2500.
If you want any reasonable shot at a 2023 Bronco, you will likely need to switch from 2-door to 4-door soft top.
