03/06/2023 Build Week
El Bronco Blanco
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
George Ellis
George
Cumming, GA
F-350 DRW CC
Oops - must be dementia. Mine is 3/13. NM
BNutFlyHawk
Paul
Boone, IA
2013 F150 XL SC 4X4 2023 Bronco 2DR
Any one else seeing the March 6th build week date slide right? Checked the "track my order" link in the email a couple times and started the 6th, then the 7th, and as of this morning now the 10th. Probably be moved to the 13th build week at this rate.
BAUS67
redneck
Central PA
I started March 6th. I checked about a week ago and it said March 10th. When I saw your post logged into my Ford account and it now says March 7th.
if I understand it right, we should get a window sticker about a week before the build date and that will have the date finalized. That will also have the blend date, when chassis meets body. Once we have that the dates should not change.
Superthornbird
Everglades
Matthew
Missouri
1965 Mustang, 2015 Outback
Everglades
The backdoor link still has the week of 3/6 the link from the scheduling email has the week of 3/10... the 6th is a Monday and the 10th is the Friday of the same week. So from that, I deduce that it will be built on a day that ends with Y.
Ohship5
Oship
South Carolina
Truck
Mine won't even come up under the tracking link. It says invalid order number (but its clearly not invalid) Ugh.
BAUS67
redneck
Central PA
That number is your dealer order number. On the DORA printout from dealer, it is in the upper right corner. Should be 4 digits I believe, mIne is 4.
El Bronco Blanco
Scottsdale, AZ
I check every day, no slide yet for mine. still holding at "week of 3/6" on the pizza tracker
Southside_Ray
Ray
Iowa
2014 Ford Fusion
Just added mine to the spreadsheet. I look forward to seeing you other Granger pick ups on the lucky day 😁
Much appreciated to all the helpful info folks!
Boltstop
Rudy
Idaho
69 Bronco 302
We all should see our Broncos in about 6 to 8 weeks more or less . I'm starting to get excited.
El Bronco Blanco
Scottsdale, AZ
MY pizza tracker now says "Week of 3/8" so to piggy back on what @Superthornbird noted, that is a Wednesday, not a "week of" so maybe it's trying to slot us based on what day it will actually get built and until its fully locked in most likely the week before, it will move that day around??
@Boltstop lets hope is "less than 8 weeks" so that Ford can give me a sweet BDay present in April.
Superthornbird
Everglades
Matthew
Missouri
Everglades
Mine now shows 3/8 as well
Ohship5
Oship
South Carolina
Truck
My account still says "week of March 6". My tracker said "Week of March 8" last week. Today my tracker says "week of March 7"...so who knows. Maybe the tracker shows the actual build date.
BAUS67
redneck
Central PA
Same here, says 3/8 today. Spent last week at 3/7. Week before was 3/10. I'm just happy it has stayed in the same week. Have seen many others get bumped around to different weeks.
