Where do you see them for $450? Are these what you installed? If so, how do you like them?Just add the Bilstein 5100 kit - its about $450 and install would be around $900+/-
you dont need new springs
spacers are sketch
spacers are sketch
I have 5100 front side 5160 on rear of my f150 and they are awesome. Ride so nice. Upgrading to 6100s on my Bronco with heavy bumper and winch. I order from here and it shipped next day.Where do you see them for $450? Are these what you installed? If so, how do you like them?
this doesnt include the strut only option with adjustable heightThank you for this
imean....google it? I see them listed for more, and for less....Where do you see them for $450? Are these what you installed? If so, how do you like them?
I can confirm (as can many others) a lift is not required to run 35 x 12.50s on a non-Sas Badlands...just need a wheel with correct offset of +30mm or less and remove the crash bars. Factory suspension on a Squatched Bronco running 35 x 12.50 on +30mm offset wheels is only lifted and additional .375" above non-Sas Badlands.I was looking to add some aftermarket wheels
Fuel Rebel 6 (17x9)
bf goodrich ko2 35”
From what I read online. In order to not rub, I would have to have a 2” lift
I’m still trying to figure out if this is true or just playing it safe
dont do spacers. junkI’m looking to add a 2” lift to my Badlands Non SAS. 2.7
I want to remove the stock 33”wheel/tires
and add some 35”.
Would I be OK with a
ZONE 2 inch spacer leveling lift kit?
Or do I need to do something like an
EIBACK Pro Lift kit (springs only)
besides being my daily driver. I do plan on doing some offroading on the weekends.
I do consider myself a beginner, so I don’t feel like I’ll be doing any major rock crawling trails for now.
but as I gain experience, down the line, I could try some more intermediate / advanced trails.
Since you have factory bilsteins, it is not a terrible option. The bump stop spacer component will reduce the maximum wheel travel capability. The preload spacer will unbalance the up-travel to down-travel ratio (and ESVC). The strut spacer component will increase the max droop, max CV angle, and max tie rod angle. It's a compromise between lift, some reduced performance, and some increased drivetrain risk.Would I be OK with a
Can you elaborate a bit more ?dont do spacers. junk
Thank you. This breakdown really helps meSince you have factory bilsteins, it is not a terrible option. The bump stop spacer component will reduce the maximum wheel travel capability. The preload spacer will unbalance the up-travel to down-travel ratio (and ESVC). The strut spacer component will increase the max droop, max CV angle, and max tie rod angle. It's a compromise between lift, some reduced performance, and some increased drivetrain risk.
The 5100's and similar are a downgrade for badlands or sasquatch (but a significant upgrade for base models). They have an adjustable preload collar, but an important note is that they are designed to work best at stock sasquatch ride height (proper up-travel to down-travel ratio). Down-travel will suck if you set preload for 2" lift above BL, but it would be fine for street use.
Thank you. This info is really helping me with making my final decision.I can confirm (as can many others) a lift is not required to run 35 x 12.50s on a non-Sas Badlands...just need a wheel with correct offset of +30mm or less and remove the crash bars. Factory suspension on a Squatched Bronco running 35 x 12.50 on +30mm offset wheels is only lifted and additional .375" above non-Sas Badlands.
It mostly depends on what ground clearance or look you want.I was told by one of the service guys at Ford to just do a simple 2” spacers lift kit. And that would minimize changing the way all the other suspension components Were designed to function on the Badland.
And I was told it was the most cost effective but safest, being that it was done by a dealership and any issues would fall under the warranty and be fixed promptly.
but then I was told by another dealership service employee, that I should just find some Sasquatch (springs, shocks kit) take off’s and just install them on to my badlands.
Your thoughts?
There’s nothing inherently “junk” about a spacer lift but it does have major down sides depending on how you’re using it. The benefit of a spacer lift is it keeps your exact ride quality/strut performance as you remain right in the middle of the window where the shock was designed to perform. The significant downside is it doesn’t limit downtravel so at full droop you’re now significantly more extended than you would have been otherwise and it puts major stress on your CV’s and Tie rods (which is where folks are having issues when they add spacer lifts and don’t know how to offroad properly). If you simply jam a 2-3” spacer up there and do any real off-roading expect to have issues at some point with tie rods/rack and CV’s. With a front wheel off the ground and severely over-extended and it comes down and makes contact w/ traction when you’re on the gas in 4wd the rest is history. Especially on an IFS vehicle as you don’t have the articulation of a solid axle and you’ll get a wheel off the ground a little easier.Can you elaborate a bit more ?
Have you had a bad experience in the past?
