- Alan
- Jul 15, 2020
- 36
- 483
- 1,424
- Colorado Springs, CO
- 2021 Basequatch
- Base
I’m at 200 miles and I’m taking it off roading.
Doesn't look like MY22 Owners manual is available yetFor anyone interested, the owners manual is available now.
https://www.helminc.com/helm/produc...result&Style=helm&Sku=M2DJ19A321AA&itemtype=N
Edit: it says its not able to be shipped to my address. Maybe someone else will have better luck.
Does Ford not stick those in the glove box anymore for new vehicles? Mine didn’t have one. Wondering if the dealer forgot or what…This is the link to Ford's site
https://owner.ford.com/tools/account/how-tos/owner-manuals.html?year=2021&make=Ford&model=Bronco
All digital now. Some manufacturers even go so far as to say it's a weight savings .Does Ford not stick those in the glove box anymore for new vehicles? Mine didn’t have one. Wondering if the dealer forgot or what…
Here’s the one for 2022. https://www.ford.com/support/vehicle/Bronco/2022/owner-manuals/
Wondering if I should contact my salesman or just have it printed out.
The best running new truck I ever had was a 2001 F-150 4.2 V6 with a manual trans. I was young and dumb and broke it in with a 300 mile highway trip bouncing it off the 99mph governor the entire way. Later I did a high speed run from Tucson to Laughlin for a SCORE race, chipped and averaging 110 mph in the desert night with some runs up around 125 mph (yes, young and pretty dumb).
I am doing something similar (keep varying the rpm on 30 min drive) to get to 1500mi quickly. Normally, I don’t like to add miles too quickly to a new car if it’s not my primary mode of transport. However, with the Bronco I’m very keen to enjoy it across the RPM range, both onroad and Offroad, so want the breakin to be over with quickly.Most of the break-in concern is engine related where limiting max RPM, and varying the RPM that you do use, is the primary focus. I suppose non-engine things may also be a consideration but I haven't heard of bad wheel bearings because the break-in process wasn't followed.
I did bad and used cruise control on my drive from Houston to Austin (150 miles). However, when I was using cruise I used M to select a gear every 2-5 or so minutes. This had the effect of changing engine speed by 3-400 RPM per gear. Engine touched 1800-3400 RPM, mostly 2000-2400. It was all light load. Since then I've done another 100 miles around town living at 1000-2000 RPM.
I am by no means an expert and merely explaining what I've done.
Any difference between MY 21 and 22?For anyone interested, the owners manual is available now.
I don't think much. The temp adjustment knob change is the only difference I can think of. I could be wrong, I have a 2021 so I haven't followed 2022 changes real closely.Any difference between MY 21 and 22?
