hello has anyone had this happen to them my 2022 wildtrak randomly goes into manual shift mode and then goes back out again had it happen at highway speed and driving in town
That's not normal.hello has anyone had this happen to them my 2022 wildtrak randomly goes into manual shift mode and then goes back out again had it happen at highway speed and driving in town
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.hello has anyone had this happen to them my 2022 wildtrak randomly goes into manual shift mode and then goes back out again had it happen at highway speed and driving in town
That's not normal.
I know it shows what gear it’s in on top of the rpm gauge and I can shif gears with the button then it goes away and start shifting automatically againThat's not normal.
I had that happen a few time and it just happened about five minutes ago. The indicator shows it is in D but the trans is not shifting and you can hear the engine revving! I backed off the accelerator and it started shifting normally. Another weird thing happened tonight as well. Pulling away from a stop sign it bogged down and I thought it was going to steal but then it began operating normally.hello has anyone had this happen to them my 2022 wildtrak randomly goes into manual shift mode and then goes back out again had it happen at highway speed and driving in town
Same thing happened to me just had it happen in traffic she bucked made a clunk felt like it wasn’t moving then started reving had to manually change gears with the button even this it’s in D on the dash and shifter luck I didn’t get rear endedI had that happen a few time and it just happened about five minutes ago. The indicator shows it is in D but the trans is not shifting and you can hear the engine revving! I backed off the accelerator and it started shifting normally. Another weird thing happened tonight as well. Pulling away from a stop sign it bogged down and I thought it was going to steal but then it began operating normally.
Did the indicator on the dash show that it was in Manual? The few times mine did this the indicator still showed it was in Drive.When it did this on mine, I realized that I was drumming the button on the side of the shifter to the awesome sounds coming from my B&O. Sometimes it gets inadvertently pressed while I'm resting my hand on the shifter as well. It does switch back quickly.
Yeah - it shows a 'random number' (the gear) on the dash.Did the indicator on the dash show that it was in Manual? The few times mine did this the indicator still showed it was in Drive.
Do you have the bulletin?so my bronco is at the dealer Now this is a known problem and they are doing a reprogram and Calibration there is a bulletin out about it
