Quitefrankly
WA
Your build looks great, but your knowledge and life looks even better. Congrats bro, enjoy the sick ride!
TEAMSLO
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White & 22' JLURD
Added some ditch lights, instead of squadron pros as on my other rig, decided to get the XL80. Originally was going with the LP4 but made more sense for these.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231114_075529
The light brackets are not going to work for me as they will vibrate/rattle on the trail.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231114_075619
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231114_075551
I have now ordered the @4x4TruckLEDs.com mount which will be much more solid. No glare on hood as these are meant to be true ditch lights. Between these and the LP6 on the front, the coverage/FOV is great. Will get a pic from a night run once I get the new mounts. Not affiliated with 4x4truckleds but here is the kit I ordered.
https://www.4x4truckleds.com/kr-off-road-a-pillar-ditch-light-brackets-for-2021-ford-bronco-pair/
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I have now ordered the @4x4TruckLEDs.com mount which will be much more solid. No glare on hood as these are meant to be true ditch lights. Between these and the LP6 on thefront, the coverage/FOV is great. Will get a pic from a night run once I get the new mounts.
Sounds good. Shoulda ordered the entire kit from us as we have a discount built into the ditch light kits BUT that's okay :) You know for next time
TEAMSLO
TEAMSLO
NV
youtube.com
You're absolutely correct, but there is some business I do try to keep local, its a tough fight. But I do appreciate the full time coupon code for Bronco6g members
colonelburke
South
2015 F150
Looks great. On the RPG collars, did you just go front or front and rear, and how much height? Thanks in advance.
TEAMSLO
TEAMSLO
NV
youtube.com
I did the full 3" front and rear. I wanted to keep the rake as I have a pretty good amount of weight in the rear. 37, reinforced hinge/tailgate, HD spare tire carrier (on its way), recovery items which weigh a hefty amount in itself, compressor, tools, ice cooler, kids lol.
The perch collar is not my permanent solution, will be going to full suspension changes but due to budget constraints, will wait on it for a bit.
TEAMSLO
TEAMSLO
NV
youtube.com
New ditch light mounts installed, no rattle even with the heavy xl80.
TEAMSLO
TEAMSLO
NV
youtube.com
RCI gas skids arrived.... I have a love/hate relationship with them, they make great quality products but packaging is the absolute worst I have even seen in my life. Im talking 25 sportbikes/builds, all my car builds both import/domestic, previous off road rigs, never had parts arrive this skimpy on packaging.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231125_172117
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231125_172128
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231125_172349
Have not installed yet, been waiting to use up some fuel to make life easier.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231125_172501
TEAMSLO
TEAMSLO
NV
youtube.com
Great call on the question, yes and no. No, the mount is not secured as it should be with both bolts. But I made it work temporarily. It does not move nor does it have any noticeable rattle for now.
From here I have several choices, get a trail sight mount, finagle something else to mount if where it is currently, or transfer to the tailgate.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231130_112125
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) 20231130_112247
Shrek27
Fullerton CA
That works. I'm sure you'd notice it moving before it fell off.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
My RCI transmission plate showed up and the box was busted open and the plastic bag that wrapped it was all scuffed up. It looked so bad, in fact, that I called and had another one being delivered until I realized that bend was meant to be there... lol Anyhow, I think FedEx did actually drop it out of the box, there's a dent on one corner where it hit the ground. It doesn't affect anything and nobody can see it, so I canceled the return. Still have to put it on, so hopefully it's not warped.
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) IMG_1820
Ford Bronco '23 4dr Bronco Wildtrak OW (daily driver and very mild build path) IMG_1821
TEAMSLO
TEAMSLO
NV
youtube.com
Its funny as they are skids and will take abuse, but just hate upon arrival, its already got some "personality".
TEAMSLO
TEAMSLO
NV
youtube.com
RCI gas tank skid installed as my WT only came with 2 straps holding up the plastic tank.
