3.5 swap?
croyco
croydon
1995 Jeep Wrangler
My thought is will a3.5 Ecoboost bolt into a 2021 Bronco with the 10 speed Auto?? If so that's the the answer for more horse power. Anybody now the answer?
tokyo
Utah / Japan
2-dr BaseSquatch 2.7
I agree
With companies like 5-star getting upwards of 500HP out of a 2.7 swapping to a 3.5 might not justify the expense. If you need more than that might as well go big and shoot for 750HP +
lobbs611
Kyle
Independence, MO
2D JL Rubicon
The 3.0L seems like a better candidate since it's based on the same block as the 2.7L. The 2.7L/3.0L was designed from the ground up to be a turbo motor which may set a higher ceiling. The 3.5L was originally an N/A motor that had forced induction added after the fact.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Anything can be done, but the 3.5 and 2.7 do not share any parts. It would require a full donor motor, exhaust, harness and all associated sensors at a minimum. Tuned 2.7 is good for 400HP and 450lb ft. of torque. That's pretty beefy without anything but a tune and intake. I think it's capable of 450HP and almost 500 lb ft of torque with additional tuning and bolt on exhaust (starts to get touchy on 93 octane fuel or even require E85, which for a daily driver, makes fuel range pretty low).
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
The 3.5 will spank the Hemi with those numbers.
bigsky713
Vernon
1975 Ford Bronco / 2002 Ford Super Duty 7.3 PS
I hope they offer an option like the power-boost that will be in the 2022 F-150 and is already in the Lincoln Navigator.
on the F-150 forums there is video of this hybrid-electric motor running 0-60 in 5 seconds. Faster than the 3.5 HO in the Raptor.
Rob1135ny
South Salem, NY
2018 Jeep Wrangler Moab
TX_Bronco77
Travis
Earth
2018 Mustang GT PP
If I wanted more HP out of my Bronco my first thought would be bigger turbos and a tune. Lost easier than an engine swap.
