mpeugeot
Just ordered a set of wheels for my BD, rim size is 17X9 with a zero offset and they have a sale on some really nice MT tires that another customer walked away from (Grabber X3).
Tire size is 295/70/17 and that translates to a roughly 33.5” tire. I’m wondering if the “0” offset will work? I’ve got no issues removing the crash bars and plan on either a small spacer lift or level kit but from what I see it’ll “fit” fine just not for off-road until I lift an inch or two?
It should fit, I went with the +30 offset, but once you remove the crash bars, it should work. 1 am going to run the 295/70R17 Milestar Patagonia M/T tires on my OBX non-SAS.
Put it in to willtheyfit.com to get a visual difference between the offsets.
Ford Bronco 33/12.5/20 tires fit on Black Diamond Bronco no problem Screenshot_20210801-090407_Chrome
Ford Bronco 33/12.5/20 tires fit on Black Diamond Bronco no problem Screenshot_20210801-090356_Chrome
Mustang Mike
Toronto Ontario
Mustang GT
Yah considering some videos of 35” tires fitting (albeit pretty tight) I think 33s are modest, and in the event I’m not going to do anything off pavement until I know I’m relatively “safe” probably with a 1”-2” kit down the road
lawcdav1
Lawrence
Georgia
33/12.5/20 fit my Black Diamond no problem in stock form with removing just the crash bars if this helps anyone, I could not find information on this particular size when I was looking. The rims are+1 offset.
Before I place my order. I just wanted to check in and see if you are still enjoying the 20in wheels. I plan on doing a similar setup. Not sure if I need a higher gear ratio.
