34s with the 4cyl 2 door?
ecartaya
Miami, Fl
2022 Ford Bronco Black Daimond 2 dr
Greetings everyone.
First post here. See pics of my 2022 Black Daimond 2 dr manual 4cyl. Need some insight. I have the oem 265/70r17 tires and with it go to a 34x10.5r17 tire. I’m more worried about hearing and engine performance with the 4 cyl. Can it handle the larger wheels with stick gearing? I dint want to alter gearing. Thanks a lot.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
Greetings everyone.
Not sure if they’re geared differently or not with the Sasquatch, but I have a Badlands 2door with squatch and the 2.3/auto. I’m running 20x10 Fuel Blitz with 35/12.50x20 Nitto Ridge Grapplers. They weigh in around 107# per wheel/tire. The 2.3 handles it effortlessly. I’m also averaging 19.7 mpg lifetime with this combination.
Ford Bronco 34s with the 4cyl 2 door? 0314B852-EF04-436F-830F-8ABF866DF9E3
ecartaya
Miami, Fl
Not sure if they’re geared differently or not with the Sasquatch, but I have a Badlands 2door with squatch and the 2.3/auto. I’m running 20x9 Fuel Blitz with 35/12.50x29 Nitto Ridge Grapplers. They weigh in around 107# per wheel/tire. The 2.3 handles it effortlessly. I’m also averaging 19.7 mpg lifetime with this combination.
Man that’s sweet. Thanks.
ecartaya
Miami, Fl
I have a 4DR BD with 285/75R17 (34x11) and still has plenty of power. No need to regear.
No running. No issues with control arm interference? Thanks.
ProdigyJKU
Rob
2012 Wrangler
Updated:
I have a 4DR BD with 285/75R17 (34x11) and it still has plenty of power. No need to regear. Runs fine in 6th on the highway. Might dip into boost a little more while in 6th above 70mph. But still easily accelerates in top gear, even at 85mph. No need to downshift to pass cars.
Ford Bronco 34s with the 4cyl 2 door? 20211025_132740
ProdigyJKU
Rob
2012 Wrangler
Nope. I did remove the rear crash bars up front though, the tire get fairly close when turned. You could probably get away with leaving them on, but I decided to take them off just incase it gets a bit closer when flexed out.
Edit: I do have wheel spacers on.
ecartaya
Miami, Fl
Updated:
Thanks. Did you have to add spacers?
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
285/75R17 are a much less expensive option than 34x10.5R17 BFG’s and can be had in a proper C load range. I run them on my Badlands with the 2.3 and manual, no issues at all but I do have the 4.7 gearing vs your 4.46.
equitasforall
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
Greetings everyone.
Gearing shouldn't be an issue. Manuals come with 4.46 gearing as I recall, except manual Sasquatch, I believe those still run the 4.70. I'd just keep the tire/wheel combo as close to or under the weight of the stock tire/wheel combo, as you you have the "weaker" front end.
ProdigyJKU
Rob
2012 Wrangler
No, and spacers actually move it closer to the crash bars as they make the tire swing in a larger arch when turning.
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
I think you should be all set and go for it. The 2 door is also lighter than the 4 door so that's in your favor. When shopping for wheels you can look at options for weight and go for a light as possible wheel also. (Unless it's all about the looks.). The Fuel wheels look great but tend to be really heavy.
ecartaya
Miami, Fl
Thanks everyone for the quick and relevant insight. I’m gonna go with 285/75/17 BGF ATKO2 (E).
