BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
If that is a Big Tex or something close, that is a heavy trailer. (7,000-9000LB)
It looks like a 20' 100A. It's GVWR is 9,900. Trailer itself is listed as 3200 and change empty. Still heavy for an empty trailer, but just enough weight left on the Bronco's 3500 lbs tow rating for a small 250 ish pound bike ?
https://www.bigtextrailers.com/all-trailers
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I'm a graphic designer ..that's photoshopped
You can see the area they tried to patch together in the circle..
That’s just the third world MI roads!
Mattwings
Matthew
Northville, MI
I
It must be right on the nose. All sorts of modifications to that trailer, looks like they were done to reach a certain weight.
have no idea, but that was my thought too, it’s weighted to match max capacity for testing.
Rydfree
Benny
Alabama
That would be the logical answer but this is 6G , logic is out the window .
Ford is testing max towing weight .
vrtical
Doug
GSMNP, TN
Fords
Can tow 10k trailer with nothing on it ?
Jr87mustang
Josh
Northern Cali
I think they are filling in the Tow Chart Specs. OBX and BB non Sas will have the highest capacity because they don't have the steel bumpers, disconnect, and bash plates. Badlands and FE with Sas will be the worst having all the rock crawling stuff on them. Probably why you can't get a tow package with the FE. It is going to be a Jeep Gladiator situation.
Dmk08
GA
Walk
Its going to be a pathetic 3500lb in an “SUV”.
RyanM
Ryan
Ohio
2011 GMC Acadia
Found this on Facebook. Just wanted to post the picture so you can see what it looks like when the bronco four-door is towing a large trailer.
**Not my photo
OBX looking pretty good here. The painted flares don’t as bad in a darker color like this.
P52Ranch
Bryan
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
Definitely a 100a. Looks more like a 16’. That’s still 3000# empty. More importantly that’s a 400# tongue weight empty.
Even with no passengers or luggage the rear suspension doesn’t seem to be sagging much
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
Maybe and this is just speculating they installed heavier springs for testing!!!
Rydfree
Benny
Alabama
The Bronco is an off road specialist though . If you want a SUV that tows more , there are other options .
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
It would be awesome if Ford was sandbagging the whole time and the final tow numbers are much higher
The tow numbers probably reflect the short wheelbase - even with electronics you can't keep up with it in the western wind. Ten miles to the equipment rental place you could white knuckle cheat it.
