- Mr Bojangles
- Sep 16, 2021
- 21
- 65
- 184
- Denver
- Website
- quakeled.com
- 2021 Bronco
- Undecided
Let's be honest, the cargo area lighting in the 2021+ Ford Broncos is not even close to sufficient! With a rear seat that blocks the stock dome light, you're better off keeping a lightsaber in your back pocket for those times you actually need to see back there. For those of us who don't have this Jedi luxury, the mad lighting scientists at Quake LED have come to the rescue with the ultimate Bronco cargo area LED lighting solution!
This easy-to-install, 39-inch Rear Window LED Interior Light Bar mounts permanently to the lower section of the rear window to provide ample light both inside and out on BOTH soft and hard top models! This flexible Interior Light Bar easily bends to match the contour of the Broncos rear window for that super polished, OEM look. The 3M UHB adhesive backing makes this install a breeze. All parts included to install from start to finish, including a quality CNC precision metal push button switch with LED halo ring, fused wire harness, and ample wires to get the job done. Go ahead and power your interior lightbar with our dual trigger input technology via a metal push button switch, and/or hard wire it to trigger off of another accessory to bypass the switch.
At Quake LED we understand that our Broncos often bring us to remote places far away from convenience stores or delivery guys. With our design, you'll never be stuck 50 miles away from a store looking for an uncommon remote battery to turn on your Interior Light Bar or trying to buy another remote control because your thin plastic remote is broken or lost.
If you're like us, we love to get out and remove the top during those hot summer nights. This interior lightbar can be quickly disconnected without any tools or needing to remove it from its location in a matter of seconds. When you are ready to reinstall the top, just reconnect and you're ready to go.
Perfect for: Camping, tailgating, loading, unloading, cargo area repairs and more... If you own a Ford Bronco you NEED this very simple, easy-to-install rear window interior lighting upgrade!
Retailing at only $131.98, this is an extremely affordable lighting solution that is a must have for anyone that would like to see what was once hidden in their rear cargo area!
Get yours here:
39" Ford Bronco LED Interior Light Bar (quakeled.com)
Or from:
Quadratec, Northridge 4x4, Meyer, or Keystone
Model Number: QTE1306
Get yours here:
Or from:
