TC1
Tony
Norwalk, Iowa
2022 Bronco, 2022 Mach E, 2021 Escape, 2014 RX 450
So I towed with my Bronco/ Wildtrak w/ HOSS 3.0 Suspension / 2 door last night. Small trailer with big mower est. 1500lbs. Pulled great with zero issues. We have an uphill ramp onto the interstate my 3.5 eco boost F-150 pulled to 70mph easily, our 3.0 Ecoboost Explorer would get there if you was into the gas. Bronco never went above 2500rpms and was about 72 mph at the end.
So my opinion it closer to the F-150 than an Explorer. pulled at 72 mph with no down shifting in settle hills. Filled up to get an idea on MPG 15.2 over 48 miles about 20 miles on interstate rest in traffic in town.
On of my likes is the tight turning radius. Little trailers will not turn under the truck. You can really control trailer backing up. I’m sure some rookie backing a boat up will still F things up. Experienced guys will love it.
I also noticed it was quite compared some of our other cars. SUVs are very noisy with this combo.
Lakelife36
Ben
Interior of BC
How were the dynamics on the open highway?
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
The 2 door maneuverability is so tight. Especially compared to an F150 which steers like the Titanic. It's got to be like moving a trailer around with a forklift.
Hossfire
Ken
Richmond, VA
'06 Jeep Commander
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
The thing that frustrates me about towing with the Bronco is the fact that the hitch is virtually unusable without an extension. The spare tire sits so close to the hitch that you cannot use the latch on the trailer properly unless you use a drop hitch which may not be appropriate for all trailers. Anyway, it's a minor problem & just a PIA when towing.
TC1
TC1
Tony
Norwalk, Iowa
That is exactly how it feels
Towing only 1500 lbs its going to feel ike its not even pulling a trailer.
true it didn’t even feel it back there. Which surprised me as same set up on the explorer you could tell you was pull something. The Explorer towing is much higher and motor more powerful. I’m sure it the gearing
Clint Callahan
Clint
Tennessee
2013 Toyota Tundra Rock Warrior Edition
Been think about changing to WT just to get the HOSS 3.0 when I reorder for 2023
I’m hearing it will be an option and you do not have to go Wildtrak. Can anyone confirm or deny this?
Giddyup Buttercup
2022 Ford Bronco
I have hauled 2900lbs (maxing out trailer tires) with manual ford focus' no problem. The 2-door manual Bronco makes it seem like nothing is there. Granny gear starting out on a hill is cheating.
Thiskers
Georgia
I got a 4 door. But coming from a old 2 door f150, insanely more maneuverable. Feels closer to rental cars I've had than that 2006 f150.
VictoryLights
Pittsburgh
2018 Honda Pilot
Wow…I love that build. Green with the yellow/orange is amazing
biswamberpal
Biswamber
Frisco, TX
Infiniti
how was the ride quality on highway, was it smooth or did you find suspension bit tight
TC1
TC1
Tony
Norwalk, Iowa
It was the same as normal but my trailer and mower is balanced very well there is only about 160 lbs of ton weight on the hitch
9100toZero
Pensacola
2022 Bronco Wildtrack
We pulled 3100# enclosed trailer and only got 9.6 mpg but handled great
