Status
Not open for further replies.
Boomba Racing
Boomba Racing
Wood Dale, IL
www.boombaracing.com
BRONCO
Exclusive kit for the 2.3L Ford Bronco and Ranger models.
This spacer adds volume to the air entering your head. This has been shown to aide in cylinder filling at lower RPM, smooth out throttle response, build boost sooner, and lengthen the effective wave pulse of the intake charge. In the picture shown above, you can see the dyno charts of this spacer paired with our throttle body spacer and the gains are tremendous. 10 ft lbs of torque (in using both spacers) and a significant change in the horsepower curve.
The spacer also includes 8 1/8" NPT threaded ports that can be used for aftermarket injection set-ups such as Aquamist. They come with plugs for those just wanting to use the spacer on its own.
Link To The Product
https://www.boombaracing.com/bronco-ranger-intake-manifold-throttle-body-spacer-kit/
-All hardware is included (corrosion resistant)
-Comes with engine cover stud relocation kit (allows you to use stock engine cover)
-Smooths air entering the cylinders
-Does not require a re-tune
-Greatly increases throttle response
-Improves MPG
-Available in blue, red, black, and natural finish
Ford Bronco Boomba Racing Intake Manifold and Throttle Body Spacer Combo With Dyno Results! Bronco_Spacers
Ford Bronco Boomba Racing Intake Manifold and Throttle Body Spacer Combo With Dyno Results! Bronco_Spacer_Dyno
Video proof of the run
Installation guide
https://store-o5238.mybigcommerce.com/content/Bronco 2.3 IM and TB spacer.pdf
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Over 30 ft lbs of torque
Is this a typo? Looks like the gain is 10 for each on the graph. Don't get me wrong, $300 for 10hp and 10lb-ft is a good deal. People pay a crap ton of money for less. Any options for 2.7 in the future? Is something like this even possible on it?
Thanks!
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
Thanks!
Thank you, that was not a type but not applicable to the Bronce and it has been fixed. We have our own Mustang Dynometer that is sound proof and stays temperature neutral. This allows us to consistently get reliable results. We are definitely looking into the 2.7 V6 as well!
UNBROKN
Central Virginia
Glad to help. It was on the website description too, that is why I said something. Looking forward to seeing what you have in store for the 2.7. Don't want some jerk hollering that you did not give them the gains that were "advertised".
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
The intake spacer was a legitimate mod on my Nissan. Was well worth the money on that platform.
The Ecoboost engines respond so well to modifications. Most modern DI Turbocharged engines respond well with usually very little mods.
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
Thank you, definitely will release products for the 2.7 as well, great engine with TONS of potential.
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
ahhhhhh snap. I’ve been loving your BOV since you released it. Might have to try this as well. Not for the added power but the power band. Could help in the rocks!
gunt520
1990 Ford Ranger XLT Lariat Supercab
Would you expect similar results with the Ford Performance tune already installed?
bradcd
Brad
Indiana
Saab 9-3
So what's that graph look like below 2,000 RPM?
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
Was this with stock intake? Would a bigger intake have a negative effect on this or is it only potential regardless of other mods?
FTW
Faisal
Saudi Arabia
Bronco big bend 4 doors
Link To The Product
-Improves MPG
Does it void the warranty? And do you have any installation video?
Ogre
James
I meant Air Filter intake. Not manifold.
Status
