Advice Wanted: '22 Badlands with 33" tires, wanting to upgrade tires and suspension. Thoughts?
Rd1103
Ross
Austin, TX
Subaru Forester
Hey Bronco lovers.
Like you, I've been out enjoying the Bronco, scraping skid plates and driving around town and the trails. I've seen enough sasquatch versions of the Bronco around, and although I like my 33'' tire setup, I'm seriously looking at upgrading to 35'' tires (37'' is TEMPTING, but I don't need them.)
I'm looking at the Nitto Grappler Recon 35'' tire setup, but wanted advice from you all on wheels, AND any suspension upgrades that won't break the bank (I've already spent enough this year on an Advanced Fiberglass hardtop LOL.)
Pictures, recommendations/combinations are welcome here. Thanks.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Many of us just put 35s straight on without suspension work. If you use wheels in the +15 to +30 range you should have no rubbing issues.
PWillette
Parrie
Maine
I jumped up to 35 x 10.5 on my +55 non-sas stock wheels without any rubbing issues, just removed the crash bars. If you are going with 12.5" wide tire you should go to a +30 or less offset to avoid rubbing the UCA...seems most go with zero offset.
Rd1103
Rd1103
Ross
Austin, TX
Subaru Forester
Thanks for the insight! Can you explain the numbers you mentioned (apologies, very new to this).
PWillette
Parrie
Maine
Sure...the non-sas BL wheels are +55mm offset vs, the Sas +30mm wheel offset...the Sas wheels stick out (poke) 25mm further than the non-sas. The extra 25mm of poke allows for the Sas 12.5" wide tire w/o rubbing the upper control arms. If you wanted to keep the non-sas +55mm wheels you could add a 1" spacer to get the same result as a +30mm offset wheel. Or you could go with a 10.5" wide tire and keep the non-sas +55 wheels without rubbing issues.
irishdore
Tennessee
'23 Ford Bronco Badlands, '20 Ford Expedition
Hi,
When you buy a tire, they obviously have a tire size that you seem to understand, e.g., 33 inches, 35 inches, 37 inches etc.
The 10.5 or 12.5 numbers in the responses to you are the width of the tire. If the tire is wider, then you may have rubbing... which leads us to...
The offset figures are the +55, +30 or zero offset. What is offset?
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is located in the front half of the wheel closer to the wheel face. This tucks the entire wheel in toward the brakes and vehicle suspension. Positive offset wheels are generally found on front-wheel drive cars and newer rear-wheel drive cars.
Negative
The hub mounting surface is located in the back half of the wheel closer to the back lip flange. This moves the wheel out away from the vehicle brakes and suspension. "Deep dish" wheels and wheels for lifted trucks are typically a negative offset.
Those numbers you've been provided are positive offsets of 30mm and 55mm.
Did that help?
Rd1103
Rd1103
Ross
Austin, TX
Subaru Forester
Hi,
Zero Offset
Positive
Negative
Did that help?
That's perfect, thank you for the help!
