Any idea how long the swing gate is (when open)?
Goodnoodle5
Jacob
Delray Beach, FL
BMW X5
Self-explanatory title, and has anyone had any issues with the length when someone is parked by or behind them? OBX model if that changes anything.
jasonkosi
Chilliwack, BC, Canada
I donā€™t know the exact measurement, but I havenā€™t had any problems with clearance. The gas strut also helps because it lets you open the tailgate slightly (probably between 30-40 degrees)so it doesnā€™t just fly open and smack into whatever is behind you. If you want it open to 90 degrees you have to push it past where the strut holds it. Mine is a 2 door though, so I donā€™t need to back in as deep into parking spots
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
I just park accordingly if Iā€™m opening it. Iā€™ll nose into the spot if Iā€™m going to load something. If this is a parallel parking question, ugh šŸ˜£. Itā€™s not ideal. You can get items in and out put your not opening it fully.
Ingridthehorrible
FL
2005 Chevy 2500HD, 2008 Buell 1125R, 98 Buell S1W
From the body as measured from the hinge 49-1/4 inches or 46 inches past the max rear bumper length, badlands steel rear bumper
