Any run a Pedal Commander with the Ford Peformance Tuner?
wkaotp
Sean
Portland, OR
Audi SQ5, Sprinter 4x4
Any one try this yet? I just got the Tune, and had a pedal commander prior. Havent tried it with both yet. Not sure it is doable.
wkaotp
wkaotp
Sean
Portland, OR
Why wouldn't it be?
Because the pedal commander is set to the stock tune not the Ford performance tune? I dont know thats why I'm asking.
Nosferatu
Neither here nor there
'13 F350
Pedal commander doesn't change anything with the tune, It simply interrupts the pedal input and modifies it based on your preference. Unplugging it from the ODB port completely disables it with no side effects.
Ducati1098
Neither one has anything to do with the other. They will work together perfectly fine.
UM_Ftown
98 5.9, 01 XJ
Why do people run pedal commanders with the goat modes? It doesn’t actually give you more power, just changes the throttle % with how much you press the gas pedal.
JediMcMuffin
Tommy
2021 Bronco Badlands
It’s like having a short throw shifter. Less pressure is required.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
To answer OP's original question, I have both, and yes they work fine together
Mattyfly42
Matt
2021 4 door 2.3L MT
I have both and they pair up nicely.
