So rightReally...Wouldn't it be easier to just try the settings...
Kinda like the Turtle and Rabbit for a John Deere throttle lever.Really...Wouldn't it be easier to just try the settings...
Nope..I'm a base owner. Not smart enuf for these new fangled inventions.Base bronco doesn't have this does it?
ford could have avoided much of this confusion if AUTO meant the same thing as all my other vehicles that have auto-SENSING wipers.There is a newer manual in the ford pass app marked 12/4/23 that shows one additional setting (off).
A, high, roll the knob away from you
B low, roll back one click down from high
C Auto, 2 clicks down from high or one up from off
D off
The ring closer to the steering wheel works the rear wiper if equipped.
I would bet if you roll the knob past high it will squirt washer fluid.
This was on page 106 I believe:
Suppose to clean your windshieldWhat's up with the rain drops vs the dashes?
Wow...just WOW!So I guess the answer to my original question is no, no one knows how they are supposed to work. We all know how they seem to actually work, but there must be more to it than that.
Thank you. The fact that its not clear how the are meant to work seems crazy. They don't work how any other modern-ish car works. I don't think they are meant to just get progressively faster or they wouldn't be labeled that way.Ok yaāll, devilās advocate here ā¦ while Iām firmly in the RTFM group, the manual does not specify what each tic does. Being that I just got the recall for the wiper motor reprogramming, the motor DOES have a load response, itās just unclear if the individual options avoid that computer control. Other vehicles Iāve had have the option to turn off a rain sensing wipe feature (I was tired of my van going into turbo mode every 10 secs) so that was something I looked at in the beginning.
Since Iāve never had a wiper malfunction, I canāt say what setting would be used in that scenario, but Iām getting the feeling that the triple droplet tic may indicate an auto feature of sorts. I really only use level 1 or 2, or full tilt, but the other day the triple tic option does seem more randomized. My 2021 manual only shows A:high speed B:intermittent (3 functions) C: off
Even funnier than your "joke" is that you got it backwardsYeah, and what's with the turn signal lever? Pull it up to signal left, push down to signal right. How do they expect you to remember that?
