aub957
Aubrey
dallas, tx
AR | STIRRUP®
*SHIPPING Mid-January 2022*
The BRONCO community asked for it and we went to work! After reviewing what was shared from last year's SEMA Bronco, there was plenty of room for improvement, both in design and function.
Made from a sizeable chunk of 6061 billet, the STIRRUP is very beefy part and it will look right at home on an overland build, trail conquering rig, or your daily driver. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle. The entire part is coated in RAL 9011 Graphite Black, then post machined to remove the coating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the STIRRUP years and years of rugged good looks. The more you step on the the more naturally worn the aluminum will look but it won't affect the Graphite Black coating.
The STIRRUP is mounted to your OEM rocker rail with M8 and M10 316 stainless fasteners. A single M8 bolt alone has 110,000 PSI tensile strength! The STIRRUP is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the STIRRUP will require little maintenance and it will last the life of your Bronco.
The STIRRUP will be sold in pairs. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount. We're going to handle the purchasing a little differently this time....
AR | STIRRUP DROP BRACKET
Renders are below. The drop available from the standard STIRRUP is difference making 2". The drop bracket is substantially larger than the standard bracket. The STIRRUP Drop Bracket has been updated to the listing on the website as an option. For the majority of use cases the 2" drop would make a lot of sense.
The Drop Brackets retain all of the same ruggedness of the standard brackets. The exact same rail mount locations are used between the two brackets. So if for any reason you want to swap to a drop bracket down the road, it's a simple order and install deal. The Drop Brackets retain all of the same ruggedness of the standard brackets. They do hang down just that little bit more, so that's something to keep in mind if you do happen to find that trail with large rocks.
Drop Brackets are added to the website as both an option and will also be added later as a stand alone product. If you already have the STIRRUPS on order but want the Drop Brackets instead, email [email protected] with your Order Number. We'll make the note to your order on the back end so you receive the brackets you want, but you'll check out on the website for the new brackets, if it turns out that there's a substantial cost difference. There is no cost difference to change your order to the Drop Bracket.
Pricing:
Retail price for the AR | STIRRUP is $494.43
BRONCO6G members are eligible for a 20% discount, making the price per pair: $395.55
NOW TO THE FUN PART:
If you would like to pre-order your STIRRUP pair or set of four now, here's what you'll need to do.
1. Reply in this thread: SEND IT!
2. We will PM you with a one time use code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, to the STIRRUP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your STIRRUPS to arrive.
Send it! [please :) ]
85BroncoFirstCar
Chevy Chase, MD
'17 Toyota Sienna, '13 Land Rover LR4, '21 Bronco
AR | STIRRUP®
Pricing:
Send it!
TyGuy40
Ty
Austin,TX
Triumph Bonneville
AR | STIRRUP®
Pricing:
SEND IT!
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Send it!
Also is the 2" drop bracket something I have to order? Post #1 sounds like it's a selection I have to make at order time, but the AR website makes it sound like the bracket does "standard" or 2" drop depending on how you install it.
Also can you post some renders (or better yet actual pics!) comparing the standard and 2" drop mounts?
It’s one bracket design that allows you to mount it even with the rail or with a 2” drop 😎 you can configure out however you want!
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
Sent it for a 4 dr set.
Hazen75
Hazen
Memphis
2011 Ford Explorer Limited
AR | STIRRUP®
Pricing:
SEND IT!
BobaFetz
Madisonville, LA
Sierra
AR | STIRRUP®
Pricing:
Send it!!
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Shipping in mid-January but still no photos of the actual product?
Man, y’all are anal. It’s January 5. Curtis sticks to his promises. PRE-ORDERS are going to start receiving them as soon as they’re finished. Just like the BYOD and TAP. Photos didn’t appear until they were being shipped. We committed because we trust AR craftsmanship. I’m sure there will be 25 install threads soon. Don’t fret.
