Wanted to run a possible audio upgrade through the collective wisdom of this group. I know there are a lot of auto threads here and I’ve tried to read though most of them – thanks to everyone who has posted. This is all great information and much appreciated.
Have a 4-door 2023 Badlands, non-B&O with the factory subwoofer set up. Like most, my goal is to have clean, clear sound and not trying to wake the neighbors.
Proposed setup:
Dash - I have replaced the front dash speakers with Audiofrog GS42 and very happy with the sound. With an aftermarket amp, would I need bass blockers?
Kick panel – Open to suggestions here. Are most doing 2-way or midrange? I know many have said the factory speakers are OK so may not prioritize these until later.
Pods – Will likely replace with the same Audiofrog GS 42. I don’t know that upgrading to a larger speaker would make an appreciable difference?
Amp – Kicker Key 200.4. Seems to be the amp of choice for the Bronco, but curious if it will underpower the proposed speaker set up? Main question here is, is this amp a good match for the Audiofrog and kick s panel speakers? The Audiofrogs have a power range of 15-50 watts RMS which is the top end for the Kicker 200.4 – is this ok?
Subwoofer – Replaced factory sub with Kicker 48CWRT674 but feel it is still very underwhelming. Again, not looking to rattle the license plate just want to fill in the lows. Options would be to upgrade the sub to a larger kicker and/or replace the factory amp with the Kicker Key 500.1. Do you think the 6 ¾ sub is large enough if powered by an aftermarket sup to round out the sound?
Amp – Kicker Key 500.1. If decide to go with replacing the factory amp.
Thanks and appreciate any insight.
Proposed setup:
