Auto Start Stop Eliminator Freebie
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
wcmaness
Wesly
Arlington, TX
'21 Bronco OBX; '11 Armada; '02 Tahoe Z71; '91 XJ6
That’s what I don’t get. What’s annoying about it?
It's quite irritating in Texas when you want the A/C compressor to keep turning at a stop light in 112 degree weather. No - it doesn't keep the engine running just because you have the A/C on and it's sweltering hot.
drew707
Ford Explorer
yes. I have taken the HVAC assembly out a few times for other add-on installs and I can tell you, the A.S.S. button has its own connector
On our Broncos it definitely does not. It’s integrated into connector C2010, the audio control panel (volume knobs) which is a 10 pin connector. As I’ve previously stated the wire for auto start stop is pin 4 and is solid brown. I however don’t know what you’re supposed to pull to as the f-150 method is supposed to have you jumper it with the hazards.
Update I was wrong there’s two. Pin 4 which is brown as previously stated but there’s also pin 7 which is white with brown stripe.
Pin 4 feeds out of the audio control panel and goes to pin 13 on the hvac control module and pin 7 goes to pin 5 of the hvac control module.
j_anderson
Fort Wayne, IN
www.instagram.com
It is integrated but the stop start eliminator is plugged into the smaller connector in the middle of the unit. I made the assumption that one was for the stop/start button.
drew707
Ford Explorer
From the F150, the wires used for the ASS jumper are the purple and white wires. Jump by either splicing a wire between the 2 wires or shoving wire in the back of the harness until its secure and wont move. I used a paper clip and never had an issue with it. Hopefully you find it with the wiring diagram.
Okay I just looked at how this works I was wrong.
You want to jump the white with brown stripe wire to the black with grey stripe wire. Sorry I got confused on what and how to do this as I've never seen it done before.
Ohenry
Blake
Cumming Ga
2017 F150
I had a 2008 Escape hybrid and it would turn off the motor at under 20 MPH so I hated it in GA as well. Winter is OK but no AC in the summer and in the south not good! I had my 2017 F150 I just unplugged the trailer light fuse and drive. Not with all these modern sensors with cross traffic motoring it all!
Bob Blaylock
Bob
2016 Dodge Dart
A hybrid is a different beast entirely. Not at all comparable to a non-hybrid internal-combustion-engined vehicle that gratuitously shuts its engine off when at a stop, making you wait for it to restart when you need to get moving again.
Leaving you intermittently without AC is part of the intended price for being “green”.
jbacchi70
Joe
Jeep GC, 1968 Plymouth Road Runner
So far, I remain convinced that this product, or something similar, is the best solution to ASS…
https://www.autostopeliminator.com/collections/ford/products/2021-ford-bronco-autostop-eliminator
As I understand it, all it does, each time you start your engine, is simulate you pushing the button to disable ASS, without otherwise doing anything to alter the operation of your vehicle.
This is by far the best mod I've done to my Bronco. I'll never understand why people are ok with having to remember to push a button each time they start their vehicle or leaving it on for that matter. It should never be there in the first place.
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
I took my Bronco on some ranch roads last weekend, that require a lot of stopping and opening gates. Sometimes 2 gates, 50 yards from each other. That's a lot of shutting down the engine with the oil still hot from the turbo. Then I drove in town, having it stop every light and stop sign, 30 times in an hour in town. Then I went on a scenic drive with my wife in the mountains, pausing from time to time at every scenic overlook for a minute to look. Engine cutting off every time. I was a tech in the Navy, it's not good for equipment to have to restart them this often. Something is going to break, and leave you stranded until you buy a new starter, figure out the glitching electronics or computer. I'll disable as soon as I pick a method.
Dmorty217
Derek
Venice FL
Camery
I just don’t get the hate for for auto stop/start. It’s much less intrusive than just about any other auto stop/start system I’ve driven with.
Why the need to disable it?
I live where it is hot all year round and very hot in the summer. Not only is annoying to have your vehicle constantly shut off and start up every time you stop, your AC doesn’t stay cold but for a few seconds which is not acceptable.
Aman
Aman
Northern NJ
Anyone here put a car into N, and shut off waiting for a train?
I'll put my Bronco into N at a light or waiting for a train, but can't see any reason that I would want to shut off the engine.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
So you’ve been through a summer with the Bronco? That’s a bummer about the A/C. Would think designers would make it so the engine will stay running so the HVAC system will keep the cabin where you set the temperature.
Dmorty217
Derek
Venice FL
Camery
No not with the bronco but with other vehicles that have the same tech, I can’t imagine they differ much on functions. Someone else in the thread said the Bronco didn’t do the shut off in the cold, but did with the AC on and that is my experience with this feature on several other vehicle manufacturers.
mikec426
Russellville, AR
Ok, so not a confirmed problem with the Bronco. Thank you.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
On my F150 if the A/C is on the ASS will not kick in as long is the fan is turned up above low
