Aux Switch Uses - Ideas??
mostly harmless
Austin, TX
2012 RAM 1500
So there are six included/available factory installed auxiliary switches (depending on the model you are getting) for the new Broncos. I for one will probably not be mounting six switches worth of aftermarket lighting to my Bronco. So I am looking for other ideas for how to put these switches to use.
I have heard a few ideas already, such as running a mini fridge or winches. What are some other good uses for these switches?
Or what about less practical, but nonetheless amusing uses for them? I was thinking about labeling one of the buttons “DO NOT TOUCH!” and also rigging it to spray water in the passenger’s face if they flip it.
So let’s hear everybody’s ideas!!
Ford Bronco Aux Switch Uses - Ideas?? C3272160-B1D6-4BD0-8297-B29F66B31FC2
Lowcountry Bronco
William
South Carolina Lowcountry
This ...
Ford Bronco Aux Switch Uses - Ideas?? James-Bonds-DB5-Gadgets
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
I read it somewhere that each Aux switch has a certain fuse rating. I'll try and find it. But if I do get the BD with the Aux switches, I'll have something like the below:
1. Front bumper lights.
2. Rear rack or bumper lights.
3. Side lights.
4. Compressor.
5. Thinking of putting a wireless charging pad somewhere in the centre console. So maybe that.
BroncoKong Jr.
Andrew
Do they stay powered when the ignition is off, I could see wanting both scenarios?
Can you rig one so the vehicle can’t be started? Thinking mad max fury road lol
On Jeeps you can do either through the menu. Plus they can be momentary or latching. Hopefully it's the same.
pan-y-cerveza
Manitoba
Tacoma Pro
I'll run one as a kill switch to the 12v auxiliary in the 7pin trailer wiring.
Maybe a single spot light somewhere.
Not likely much else.
tb8983
Forest Grove
2018 F150 1993 SSP mustang notchback
Cowl lights
Foglights(rigid lights on modular steel bumper)
Train horn(yes im putting one on, they make it for the jeep)
Cb radio
Air compressor
