- First Name
- Frank
- Joined
- Aug 26, 2020
- Threads
- 7
- Messages
- 68
- Reaction score
- 120
- Location
- New Hampshire
- Vehicle(s)
- 2019 Ford Ranger
- Your Bronco Model
- Wildtrak
To make it easier to add accessories over time and to allow switches to be reordered easily, I added waterproof connectors to Ford’s dangling aux wires. I chose the Deutsch DT 2-pin connectors that are commonly used in offroad lighting. A ground is added to each connector for ease of use. They can be labeled with a sharpie or cable tag. Tesa 51608 tape is awesome for wrapping wires.
Deutsch DT connectors are easy to assemble if you buy a $25 barrel crimper and use solid barrel terminals. The DT connectors are good up to 13 Amps, or the larger DTP connectors can do 25A. The only other tools needed are wire stripper and needle-nose pliers. Be sure to buy only the solid barrel crimp terminals.
TE is the name-brand connector, or you can buy cheaper versions. I like to use the TE version for 16-20AWG and the JRready brand for 16AWG wires (JRready works with a wider range of AWG only if you use their very expensive crimper). The Bronco AUX wires are 16AWG (AUX1-2) and 18AWG (AUX3-6). The TE connectors are cheaper on ebay. You can also buy pre-assembled cables that are handy.
Unused connectors should have a sealed dust cap. You can make one from a connector and plastic “dummy pins” to seal the wire holes. With some banana plugs you can make a connector for your voltmeter to easily test your wiring.
If you also want accessory (non-aux-switch) power, you can order the extra terminal to access the existing outfitter fuse. Ford DU2Z-14474-JA. Cheapest to buy on ebay, since dealer will probably make you buy a pack of 5. Add terminal to BCM connector on fuse panel under dash and route through designated grommet on firewall (explained in Bronco Equipment Installation Guide and Trailer Tow Install manual). While I was at it, I also added DT connectors at the interior fuse box for accessory power and also one for an aux switch (from under-hood aux wire to control interior accessory).
Example parts and tools:
Tesa tape
DT barrel terminal crimper
2-pin DT connector (TE 16-20AWG solid barrel terminal)
2-pin DT connector (JRready 16AWG solid barrel terminal)
DT dummy plugs (for unused connectors)
Pre-built cable
Pre-built cable
Pre-built cable
