Barricade HD Adventure rack on soft top?
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Bump…
I am buying this soon. Questions I have…
Can the soft top still open at the rear door without removing crossbars?
Can the cross bars be put in any location along the top?
orion
Jeremy
17' F-250, 17' Explorer
Bump…
Did you buy this yet?
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Just bought it this morning. Should be here 1-2 weeks.
I have a 200lb Tepui RTT and an OVS 180 Awning to put on it. Spoke with extreme terrain, they told me max dynamic load was 350lbs (should be good there) but static max was not given. I assume as with the other comparable racks static is near 800lb.
Extreme Terrain would not provide me with the install manual prior my purchase. Does anyone have a pdf of the manual to share??? If not I will be sure to .pdf the hardcopy I receive.
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Forgot to mention. The cross bars cannot be relocated. I believe they told me the rear hatch can be opened with the cross bars in place. I guess we will find out soon.
Repins
Keith
CA
@LanceIto How did the install go? Were you able to do it alone? And does the rear open up after installed.
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Easy solo-install but time consuming. Rack is good. Get what you pay for. I am happy with my purchase although I have put a 200lb RTT and 50lb awning on it and I am a bit nervous. I might have been better choosing the Gobi.
There are holes to mount the cross bars in 6 locations and they provide you with 4 cross bars so there is some location variability. I am able to fully open the rear soft top hatch.
Ford Bronco Barricade HD Adventure rack on soft top? DE0074E2-6D88-4B7A-9137-106B4D430108
Ford Bronco Barricade HD Adventure rack on soft top? 5B4445F7-DFC7-4D2F-9DAD-E59303511A1F
broadicustomworks
Hanging Rock, North Carolina
I'd like to see that manual if you have it handy...
Thanks!
UneducatedPhilly
Phil
SC
2023 Bronco Outer Banks
Are you able to still open the soft top with the rack on top?
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
The 4 crossbars need to be removed to fully retract the top.
Rebel Bronc
Central NY
'22 Bronco 7spd Badlands
If only it was made from aluminum…
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Its there but I cant remember it without the rack. There are no whistles or other weird wind noises. I took off their front fairing and it helped.
