Best AT tire replacement for Sasquatch?
Allenkoz
Allen
Brutus, MI
2010 Ford Expedition
Hello fellow Bronco brethren, I just ordered my Outer Banks w/sasquatch pkg. During the test drive I found the stock Goodyear Territory MTs to be bouncy and more uncomfortable than I will be able to stomach for daily driving. Question, what are the best riding AT tires that I should consider as a replacement for highways and paved country roads, with occasional gravel and rare offroad? Good performance in rain and snow are important as well while not sacrificing the rugged look. Thank you in advance for your advice and opinions!
DA JUICE
Chicago
4 Wheels, 3 pedals, goes forward
I will likely replace my Territories with KO2s (or likely KO3s by then). I was originally concerned about the orginal rubber. But I have found them pretty good for daily driving, FWIW. Make sure the pressure is set correctly (air them down a bit).
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Air them down, the dealer probably set them at 48 lbs. They’re actually a good tire for what you stated. Unless you plan on driving on a lot of gravel, as they tend to throw rocks.
@Allenkoz - this is the answer. Off the lot my KO2s felt the same way. They were 10 psi over the standard tire pressure on the door frame label. Once aired down to the specified pressure it was night and day. Even the specified pressure is probably too high if you do a chalk test, but start there.
Allenkoz
Allenkoz
Allen
Brutus, MI
Excellent advice- so glad I joined this group. Thank you sir.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Nitto ridge grappler. Best tires I’ve run in years
RaceRedOBX
Brock
Louisiana
2017 F-150
I would check the PSI in them as others have said. I find the factory territory MT to be very good as a daily driver. They are great on wet roads and the road noise is mild imo. I have mine at 36 psi.
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
You won't find a better everyday driving or winter tire than the territory. Set the cold pressure to what the door jam states and you will much happier. It is the lightest, best accelerating, and fuel efficient 35" tire out there. The C rated BFG KO2s are in the ballpark but still significantly heavier. Personally, I switch my territories out for the dry months and put them back on for winter. I can't find a better winter tire that still wears decently when I get off the mountain. That said, look at the Falken AT3W if you insist at swapping out. If I had to go with a one tire set-up that would be it (but I also live in serious snow country).
Carl Sagan
Brando
Huntington Beach
2022 Ford Bronco WIldtrak HOSS 3.0
I think the territory is the best tire for the bronco. It is the lightest tire out of all of the tires in the class by a significant margin. Better acceleration, fuel economy and great A/T tire all around. The other guys that say keep them at 39psi are right. Makes a big difference.
Allenkoz
Allenkoz
Allen
Brutus, MI
Excellent. Thank you for your input 👍🏻
Inlinejohn
WA
Several
If I were choosing an A/T style tire I think I'd decide between BFG KO2 and TOYO Open Country R/T
