Best Upgrade for $200 or less…GO!
STONEWALKER
STONEWALKER
Thomas
Royal Oak, MI
2023 Wildtrak, 2020 VW Cross Sport
$90 for gas struts for the hood. I access the hood (bonnet) every time I hit a trail to air back up, and it looks way cooler that the guys that have to use the prop.
$110 Molle tailgate table. More than it's use as a table, I have 4 CLIQ chairs, recovery shackle, medic kit, and a solar connector all quick strapped to the table in its closed position. Makes great use of otherwise dead space.
I’m a big fan of your practicality! Thanks for your input
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Are we going to live our life a 1/4 mile at a time.... This morning my Bronco topped out at 105 MPH on base... I am going to need two of them nitromethane setups, the big ones. 14.50's granny shifting in eco mode and not double clutching and running baja mode like I should...
After watching FX, I'm currently rewatching this franchise and this was gold to me.
STONEWALKER
STONEWALKER
Thomas
Royal Oak, MI
Put a hundred into the vehicle
Pick up a decent bottle of scotch and a few cigars
Sit back and admire your work
I’ll trade you the Scotch for Bourbon and see you there!
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
The 0.99$ plug for your air box to let blow off valve vent to atmosphere
law
Larlar
84 Bronco
i definitely want the the 4 hose system. I’ve seen that most cost about $200 without the compressor. I’ll look into this more and see what I can find. Thank you again for the recommendation.
https://fasterflate.com/
just purchased the four tire system. If you’re a veteran, they offer a discount.
da_jokker
Jeep Wrangler JKUR
Unless you are looking for name brand, you can build one cheap...
Starts with this...
1/4 Air hose 50ft ID 4mm OD 6mm... https://www.amazon.com/dp/B09KGF7DTJ
And then you just buy the fittings like...
AstroAI Air Chuck, Heavy Duty... https://www.amazon.com/dp/B078WVQL31
Control Devices - TV12 Brass Tank... https://www.amazon.com/dp/B0081TJO72?ref=ppx_pop_mob_ap_share
Pair that to whatever compressor you want. In my case I went with..
Smittybilt 2781 5.65 CFM... https://www.amazon.com/dp/B004K25GMG
Takes about 5-10 minutes to go from 20 to 35psi for all 4 Sas tires.
doo4sno
ED
Christmas Mi
22 f350 crew lariet diesel, 23 badlands 2 dr
200.00 on gas... so I can ride around my tourist town and watch all the jeep owners turn their head the other way when I cruise by. I also own 2 dr wrangler so all jeep owners are well aware what is coming at them. I've only had my bronco 2 weeks. Got a piece sign from only 1 so far.
Captain nSANEo
Grand Strand, SC
Jeep Wrangler
STONEWALKER
STONEWALKER
Thomas
Royal Oak, MI
STONEWALKER
STONEWALKER
Thomas
Royal Oak, MI
Starts with this...
That’s good thinking, thank you for sharing!
Agrod
SJ, PR
22 4dr OBX
Tex
Cliff
San Angelo
You know on second thought, maybe just a boost cow
They're great fun and super cheap
5.0to2.3
Yes, I completely comprehend. It was a joke. You can’t get anything for $200. Bet it, triple or quadruple your money, then you can get some upgrades.
Looks like you were right, absolutely no mods available under $200. What an amazing boy you are!
