Best way to lift a Wildtrak?
Bronc69
Chester County, PA
Porsche 911, 2022 X3 (wife's), 2015 GTI (sold)
I have a '23 WT with the Fox shocks.
I was thinking of doing a perch collar install, but I don't want to ruin the ride/handling. There are a few people on here that say it doesn't do anything, but I don't think it's possible to compress the spring and not affect the characteristics.
For you, without off-roading, the perch collar might work since you won't have to worry about coil bind.
You could do a small perch collar and a 1" body lift. You'd have plenty of clearance for 37's.
Or, as others have said, wait for the spring kits to come out.
For me, I'm more than likely doing to be doing a body lift. I'm only looking for a small lift to give me a little more room between the 35's and the fenders.
Heckler
Larry
San Mateo
2023 Bronco
How are different springs going to add lift without the travel of the shock also being longer? Is it just a stiffer spring that provides less sag? Seems this would affect the ride quality.
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
I was thinking the same thing....
helifino16
Ron
Mount Sinai, NY (Long Island)
Ford Bronco Best way to lift a Wildtrak? Man lifting Bronco
1st 75th ranger
jeffrey
nj
I am putting on 37s - do I just take off the factory existing 2 inch lift and put on Rough Country's 5 inch lift? is there a "better" way? thanks
this is a joke right
if your asking this your trolling or dont deserve gods gift of a bronco
any 3/4 inch lift to be safe
upper control arms and bronco buster tie rod up grade
maybe a max tire kit
or back spacing wheels but maybe not
tire carrier upgrade with third light ext
V1Rotate
Brevard, NC
2022 Wildtrak
Lift springs on the same shock just cause you to ride higher in the same stroke the shock had before.. basically simulating droop (which you lose). Similar to a perch collar really
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Let me get this straight, you want to take off a very, very nice suspension system from Ford/Fox and put on RC stuff???
You really should Not have ordered the Wildtrak with the HOSS 3.0. Just my opinion.
Rspayde
North Ga
2022 C/O Black Diamond
I'll buy those fox coil overs for $1,000 will be in your area over labor day!
Rspayde
North Ga
Shhh let them do what they want. This sounds like an awesome idea to me.
