Will there be future downloads available for more gains or is this going to be the final TQ and HP numbers from this unit?
For 91 Octane, we're pretty confident this is the best available gains possible, Pulsar XT is making over 20hp more than the competitors inline module on 91 Octane. We may expand the product to support higher octanes or Ethanol in the future however.Will there be future downloads available for more gains or is this going to be the final TQ and HP numbers from this unit?
What were the highest altitudes you tested it at? I’m regularly between 6k-10k feet with 91 octane max available.For 91 Octane, we're pretty confident this is the best available gains possible, Pulsar XT is making over 20hp more than the competitors inline module on 91 Octane. We may expand the product to support higher octanes or Ethanol in the future however.
Our headquarters are in Ogden, UT at 4400ft, but we've driven test vehicles as high as 11,000ft. The vehicle can still self correct for atmospheric changes, so there should be no concern at any elecation/temperature.What were the highest altitudes you tested it at? I’m regularly between 6k-10k feet with 91 octane max available.
Superchips is excited to announce performance tuning now available for 2021-2023 Ford Bronco equipped with 2.3L and 2.7L Ecoboost engines. The all-new Pulsar XT module is completely plug and play, adding as much as 55hp/69tq with adjustability on-the-fly through our wireless Bluetooth switch.
Download the free smartphone app for total control over your driving experience with user adjustable pedal boost settings, calibration for tire size changes, and even disable your engine auto start/stop and adjust TPMS settings. Pulsar XT requires no ECM flashing and can be removed in minutes for dealer services. Pulsar XT adds massive torque through the mid-range and completely changes how your Bronco feels on and off road.
Awesome combo. We had a few in testing with the Flowmaster kits, great setup, I think you'll be very pleased.Watched the video demos... and then ordered. As long as I was on the Holley site, I picked up the Flowmaster American Thunder axle back exhaust I'd been thinking about. That combo should make a nice little bump in power (and sound).
We don't make claims specific to OEM Warranties as those are handled case-by-case by the dealer. But our device is removable within minutes with no trace of the tuning in the system. They could possibly see that you've changed your TPMS setting or your tire size, but this is something many devices can change, including Forscan, etc...Impact on Ford warranty?
That was one of our main goals for this, we don't like that factory driving experience either. The app will have 7-preset levels for you to choose from to fine tune the pedal feel to your liking in every power level.I went ahead and purchased one. I'm hoping that this will take out some of the off-idle throttle lag that this Bronco is notorious for.
I have a Pedal Commander installed right now. It'll be interesting to see going from that to this.I went ahead and purchased one. I'm hoping that this will take out some of the off-idle throttle lag that this Bronco is notorious for.
You'll only need to change the tire size with the device if you change your original size. It will know your factory sizeI see that the tire size can be changed. I have a sasquatch which comes with larger 35s. Do I need to specify that in the config when I start using, or can I just ignore it and the module won't try to adjust what is already in the ecu/pcm for the speedometer? Thanks!
