Looking forward to see this come to the California market. Bone head state
Same, only because I have one as wellI am interested, but want to see the effects applied to those that have had the ford tune first and those that have upgraded the IC. I also wonder with these upgrades I should add catch cans.
We'll order one in and test it, we are working on flash tuning for the Bronco as well, which will include both ECM and TCM mapping. But we're still a little ways out on that. So this inline module is an excellent way to pick up some power and have some feature control without reflashing.Would you/could you please test it with the Ford Performance tune delivered via the ProCal? That tune apparently remaps the 10 speed quite effectively but I have a feeling the power gains from both devices/tunes are coming from similar/same adjustments.
I’m guessing if a Forscan adjustment is replicated by a tuner/tune that conflicts could arise? CELs? SuperChips is willing to test stacking their product(s) with the Ford Performance tune delivered via the ProCal but that flash is an OEM offering.I called SuperChips to see if the tune would wipe my Forscan programming. They have no idea. They said they do not test their products with other after market products. If anyone has tested it, please post the results.
Not with this device, but that is a feature we have on our request list for flash tuning when we have it available.Is there a way to set the vehicle start up mode to the last mode used? Such as Eco, Normal, Sport, etc. or to always start in the mode of choice.
Start Stop works differently between the 21-22 and the 23 models, but we are sending a signal to the PCM so that it sees a situation where it would not normally enable Start Stop.I've got a few questions about this device:
1. Does it disable auto start/stop by re-configuring modules or emulating the signals sent by the button on the dash?
2. Is the pedal position sensor connection required?
3. This device intercepts signals from two pressure sensors and modifies them before they reach the PCM. How does the PCM maintain proper AFRs even though it isn't seeing the truth from these two sensors?
Unfortunately, we can not control Rev matching with this module, but it is being developed for our flash tuning. We'll see if we can get a Procal for our own testing and see how the devices work in conjunction.Very interesting but I REALLY want the rev matching with ford's procal. So it has to be safe to use with that installed if it can't give us revmatch itself.
The device passed our in-house emissions testing, so we know it will pass at CARB and we have our application in for the EO approval. But they are extremely backed up, so we can't say on an ETA on 50-state complianceLooking forward to see this come to the California market. Bone head state
We do all our testing and development around 91 Octane. So all calibrations and those power gains are specific to 91. I'll make sure our website is updated to show this as well.I'd like to confirm that the max power gains were done on 91 octane and that there were no concerns with pinging, heat, or CELs. I didn't see any talk of fuel octanes in your information, which these types of numbers usually require 93 octane to accomplish. I would love to add a tuner, but around here I am limited to 91 and don't want to spend money on something that requires 93 to achieve the advertised numbers.
Unfortunately, no, we have no control over that feature with this inline module, but should be possible when we release flash tuning.Does this remove the limiter?
We're confident this device will work with the 3.0L as well, but have to get one in locally to test on and run through our emissions cell, as the 2.3/2.7 and the 3.0 are in different emissions tiers.Where's the 3.0 ??
Did you have any intake or exhaust modifications in place to get the power gains?We'll order one in and test it, we are working on flash tuning for the Bronco as well, which will include both ECM and TCM mapping. But we're still a little ways out on that. So this inline module is an excellent way to pick up some power and have some feature control without reflashing.
Can you explain the difference(s), I’m just curious…Start Stop works differently between the 21-22 and the 23 models
No, our marketed/shared data comes from 100% factory vehicles. We did test in some modified applications with great results as well however.Did you have any intake or exhaust modifications in place to get the power gains?
Thank you, wonder if Ford will update the 21-22 A.S.S. to 23 specifications via an OTA update?No, our marketed/shared data comes from 100% factory vehicles. We did test in some modified applications with great results as well however.
Ford just changed the way the Start Stop system functions in the 2023 models
Send me one I'll give it a shakedownWe're confident this device will work with the 3.0L as well, but have to get one in locally to test on and run through our emissions cell, as the 2.3/2.7 and the 3.0 are in different emissions tiers.
We aren't currently running and promos, and our next sale won't go out until Black Friday, which doesn't always include new product releases.Thank you, wonder if Ford will update the 21-22 A.S.S. to 23 specifications via an OTA update?
Any discount codes or upcoming seasonal/holiday sales?
If you'd be willing to bring it to our Sanford, FL or Ogden, UT locations for engineers to mess with for a day. No problemSend me one I'll give it a shakedown
