Big50's Badlands build
Big50
Jeremiah
Hey Guys,
I just took delivery of my Badlands 2.7 on Monday. I'm super excited to get this thing in the dirt to see what she can do. I'll be taking her down to Baja in April for a week long overland trip.
I had a good amount of parts stock piled already.
Installed mods:
- 17" Icon Rebound Pro wheels
- Gladiator 35" XT tires
- Go Rhino B20 running boards
- VHF radio & antenna mount
Yet to install:
- radio antenna. Waiting on a longer coax. I recommend getting at least a 17' coax cord if you plan on mounting the antenna in the back of the Bronco.
- Antenna
- Spare tire reinforcement brace
- trunk drawer
- tailgate table
Future mods:
- Bronco buster steering rack bushing & tie rod brace
- Icon coilover kit once it's released
- Gladiator 37's
- Hard top once available
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
Congrats on the Bronco. Pics don't seem to be working
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Hey Guys,
Installed mods:
Yet to install:
- Antenna
- trunk drawer
- tailgate table
Future mods:
- Gladiator 37's
Hey that looks really good!
What offset icons are you using? It also looks like you put Sasquatch flares on there?
I was on the fence about the 25+ wheels or zero but I like the poke you have.
Thanks
Big50
Big50
Jeremiah
Thanks
They are 0 offset. I think it’s the perfect offset for them with SAS fenders. Flares came with it ias it is a SAS package.
Medicaptain
Tim
Phoenix, AZ
2012 F150 Platinum
Hey Guys,
Installed mods:
Yet to install:
- Antenna
- trunk drawer
- tailgate table
Future mods:
- Gladiator 37's
SUPER Clean build.....well done
Big50
Big50
Jeremiah
Just wrapped up installing a VHF. Figure this could be helpful regardless of what kind of radio you run.
I decided to mount the radio just below the steering wheel via self tapping screws. I have usually mounted my radios in the center console but it would have been a PIA to run wiring into it so I opted for this. I like the easy access and it eliminates the need for a auxiliary speaker.
I'm 6'4" and my knees don't make contact at all with the radio.
I ran the power through a perfectly placed existing bung in the firewall. I just cut a slit and ran the cord through. I wired direct to the battery.
Big50
Big50
Jeremiah
Next, up was the antenna and coax.
I recommend at least 17' long coax if you route it similar to mine. To be safe 20'-23'.
I picked up this Jeep spare tire antenna mount with the intent to modify it but it was a perfect fit. I guess Ford probably uses the same supplier as Jeep for the tire mounts. Antenna mount - Amazon
Ford Bronco Big50's Badlands build jVb6cJW
Ford Bronco Big50's Badlands build xNMd8IT
I routed the coax through the vents behind the spare tire.
I then popped the plastic piece below off to access the coax and pull it through.
Ford Bronco Big50's Badlands build fobvUMm
I then popped the trim up a bit to run the coax down.
Ford Bronco Big50's Badlands build 79pQR2n
Big50
Big50
Jeremiah
If you remove the bolts holding the tie down points down, the rubber flooring can be pulled up easily. I ran the coax under that along the side to the rear seats. I then ran it in between the single seat and double to the floor. I was lazy and just ran it on the floor under the mat. I figure you'd never know it's there. I would have used the door trim but 17' wasn't long enough to take that route.
From there I ran it under this piece of the center console.
I backed out the bolt located below to run the cord up above it. It also keeps the coax from coming down.
All done!
Big50
Big50
Jeremiah
My focus has been to get the Bronco ready for it's first off-road trip. I'm heading down to KOH Thursday for a couple days and then further south to Baja.
Last to take care of was the rear storage setup. I went to install the Rough Country drawer and discovered it was damaged in shipping. The rivets had all sheared that hold the top plate to it and the lip of the shell was dented and torn a bit. I'm now returning it.
I decided to go with this setup for now. I've used a chain setup like this in my trucks for years with great success. I think all in, I spent $25 on the turnbuckles and chain. It's pretty handy to have the additional tie down options.
Ford Bronco Big50's Badlands build kC5mkse
Ford Bronco Big50's Badlands build EdehoIn
