Arcnsparks
Jon
Indianapolis, IN
2015 JKRU
I'm hoping it does! I don't imagine it'll be a problem. For easy removal down the road the generous film thickness will be key on the MIC since it's textured.
Mpatient1
Mel
FLORIDA
'22 BD CO/MID, 2006 mustang pony package
Do you think it would stick to the MIC?
In my experience it sticks to most anything, just needs to be clean. My main thought with the MIC is no permanent changes needed to apply the product. Unlike paint where you'll be scuffing/sanding priming and never be able to get it back to original.
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
my recommendation is not to do large pieces or multiple things around the car, it'll start looking cheap. my brother did various parts on his Ram that were chrome. it started looking off and cheap. over time it started going greyish and it looks very beat up.
If it hasnā€™t been answered how did u stick it back on
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Id say you really did overkill on the spray. I did the plasti dip on my jku rims (say what you want) but I wanted to keep stock. Buddy said "I give it two months and they peel... Well couple trails later, some tire changes and they still hold up.
Future reference just use post cards under it. You wouldn't have to have peeled all that extra spray
bwomp91
bwomp91
Brad
2019 Ranger
did it today and Like the outcome
Looks great! I see you added the Bronco script on the side in addition to the Badlands badge. Did you have to remove and relocate the Badlands badge? It looks lower than mine - I also have the script I want to put above Badlands but am hesitant to peel it off to place it elsewhere.
Any tips/tricks/considerations? Thanks!
Clearwater native
Tom
19F-59,16-E350, 65C10,05TJ, 67RSCamaro, 65malibuSS
Yes my badlands badge came off easy and I re stuck it lower to make room for the Bronco Script the advice I have is to measure every thing and use a pencil or masking tape to make lines so it all looks straight (I admit mine are not perfect) Good Luck!
DapperDeeds
Company
Hey Looking to do this to the emblem and beauty rings when mine comes in. How did you get yours so smooth and glossed looking? I've seen a lot that look dimply and almost like cast iron. Did you sand and or add glossifier?
Stache12
Wisconsin
Ford Explorer, Chevy Cruze
you can buy plasti dip that has a gloss finish. Although looking at his cans in the picture it doesn't say gloss black
Clearwater native
Tom
I always do 7 or 8 thin wet coats (no sanding just plastic dip prep cleaner) and it comes out nice and yes you can use glossifier but I wanted to matt black look.
Fade2Black
JT
Austin, Texas
2022 Black Diamond Sashquatch
I just bought a replacement black emblem for mine, BUT I absolutely appreciate your project and outcome. Nice job.
Docindahouze
Doc
Cumming, GA
Current: 2016 Ford F-150 King Ranch
Nice spray job, well done.
Good olā€™ Plasti-dip - is. there anything it canā€˜t do?
šŸ˜‰
Itā€™s like hot sauce, you can put that scheisse on everything.
