Budget rocker / pinch weld modification with Plasti Dip
broncocoy
Joe
Minnesota
2013 Audi A5 Cabriolet
Had some time this afternoon to knockout a quick mod that’s been on the list. I originally planned on adding rock sliders or the Ford black plastic rocker/pick weld covers. But being honest with myself I won’t be off roading to the point that’d be needed…. I decided to try this budget option ($16). I plasti dipped the pinch weld, which visually cleans up the look down there and give the bronco (appearance wise) another inch of ground clearance. Took 2 hours total and turned out great! If I decide to add rock sliders etc later, this mid has compromised nothing in the way of doing that.
Ford Bronco Budget rocker / pinch weld modification with Plasti Dip B853677A-EFE6-414F-A7CC-07269568EABF
adamruiz2001
SoCal
Ford SVT Lightning
Why not just use under coating spray? Plasti Dip will chip real easy with rocks or road debris.
Either way, it looks much better than before.
broncocoy
Joe
Minnesota
Great point, this was none committal to me, if it works out great I can always remove it and go that route for sure.
Wannabe Techie
Chicago
Looks good. And if you get running boards, it will be great too because a lot of the boards I’ve seen don’t cover up the area as well.
Dude Lar
New Jersey
2022 Ford Bronco
A few months later, I am checking in to see how the dip has kept up. Do you still have it on there? Thinking about adding this to my weekend to-do list.
KABQ
Aaron
Albuquerque, NM
Ford Bronco Budget rocker / pinch weld modification with Plasti Dip 8F54AC4B-6A98-4EE6-B55D-AF8C88CAA00E
Curious as well. Has it held up?
broncocoy
Joe
Minnesota
KABQ
Aaron
Albuquerque, NM
Yep, it has held up great, I have 5,000 miles on the bronco
Sure has, I have about 5,000 miles on the bronco since this mod and it shows no wear👍🏼
Awesome thanks!
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
I always you bedliner spray. It is as tough as nails.
Black_Stallion13
Cincinnati
Tacoma
I imagine it will hold up pretty great - rubberized Plastipid works better than paint as far as chip protection goes in my experience as long as you put the recommended 4+ coats on or whatever it calls for. I've also had great long lasting results with Rust-Oleum Flexidip. I did go with the factory Ford rocker covers and I will say the fit and finish is very nice if you do happen to peel it off down the road.
Buck₩ild
Buck
Canada
Wrangler Willys, Bronco BD, Cherokee
There's no sanding or priming involved correct?
All one has to do is clean/wipe the pinch weld, mask it and get spraying?
