Brakes on Base Bronco Same as on other models?
CarbonBronco
Tony
Socal
99 Toyota $runner
SO the Base Bronco comes with 16" wheels standard. is the brake system on the base same as the higher up models and or Sasquatch packed Broncos? ivew been debating runiong a 16" tire and wheels for more meat on my tires.
Cappy
Cappy
North Texas
2021 Ford Ranger
Like you, I want to swing big tires on small wheels. I just can't get enough information about the brake system to see where I land.
I'd really like to put 16's on if the brake system could handle it. Since I live so close to the Gas Monkey Garage in Dallas, I might just see about having the brakes upgraded from factory just to pull this off. That's if they're not suitable to that much rubber.
Toccoa
Isuzu Rodeo Sport
EvlNvrDys
Hunterdon County, NJ
Let me think... Use magnifier glass in upper right (search feature)
Ford Bronco Brakes on Base Bronco Same as on other models? SmartSelect_20210111-174712_Firefox
Get crap results like that.... Or... Ask a question and wait for @Toccoa to find answers for me.... Yeah I'd go with Option #2 as well ?
Used2jeep
Massachuvian
2007 Crown Vic P71
But @EvlNvrDys you don't want to beat on that @Toccoa DRUM too much. You wouldn't want to PAD his ego. We may want to DISCus this first... :LOL: :devilish: :alien:
CarbonBronco
CarbonBronco
Tony
Socal
99 Toyota $runner
i just want to see if the higher up models have the same brakes. if so i can always downsize to 16" wheels. no stranger to big brakes i currently run 16" wheels on my current rig with 4 piston Stoptech ST40 Calipers.
Fly by Nite
Walt
Pa
One of the insiders on the site said 'there are two brakes'. A cryptic answer, read into it as you like. I could see a heavier vehicle (4 door V6) or one with the Squatch possibly getting bigger brakes. But then again, would Ford put cheaper brakes on a lightweight Base to save a few bucks?
Jp215
James
Pennsylvania
2015 F150
Yes, those cheep asshats would absolutely do that. But I doubt they will do it. Iā€™m assuming the brakes will be the same across all trims
MaverickMan
Shane
I posed this question back in the summer. I feel like the consensus I got at the time that the brakes were the same on most models. Warthog is likely to be different. I actually hope I can talk the dealer into swapping me for a set of ranger or base steels and mount me a fresh pair of swampers I will show up with.
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
Is the wheel stud size even staying the same throughout the lineup?
Ranger is 12mm, F150 is 14. Even the heaviest Fusion they switched to 14,
which surprised me with 150 ft-lb wheel lug torque.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Get the vin number from the first base you see and first wildtrak you see and ask the parts guy to look up part#'s for pads, rotors, and calipers.
Wonder if we will be able to do this once people start getting VINs for their orders.
HoosierDaddy
Indiana
My guess:
Vehicles with the M210 front axle will get a bigger brake package.
(Squantch, BL, WT, FE)
Warthog maybe better calipers etc.
edgeflyer
2013 FX4
Sounds like a millennial trying to make sense of three foot pedals?
