Bronco logo frozen on display screen upon vehicle startup
AttackGuy64
Denton, TX
2019 Toyota 4Runner
Can you send over a message with your VIN and the name/location of your local Ford dealer? I would like to look into this frozen screen issue on my end.
I am having similar SYNC 4 issues on startup. Frozen screen, Google Maps not displayed correctly, resets itself after a few minutes then works fine.
Jon_MothaFkn_Adams
Jon
Tulsa, Ok.
2022 Explorer ST, 2021 BadSquatch
Happens to mine all the time. Also, my goggle maps will freeze up until I toggle between android auto and sync screen a couple times and it then will go back to normal.
These seem to be a common occurrence after an update I had a couple weeks back. That said, at least the update appeared to fix the "glitch" sound through the radio when backing up, parking sensors engaging, or other random times.
I get both of these issues all the time. It's a 2021 with 40k miles, so out of warranty.
clintontx
clintontx
Clinton
TX
Ford F-250
I chatted with Ford & all they could suggest was to do a manual reboot of the system. Of course that didn't fix it. Then I was instructed to call my dealership for a service appointment . The service advisor stated, "Oh my Bronco does that too", like it's perfectly normal for a brand new product to not work correctly. I don't have a lot of faith that this will be resolved by the dealer but I guess we'll see.
HeliPilot
Kenny
CT
2022 2.7L SAS
Mine has done similar stuff a few times. When it all started functioning normally again, I immediately turned off OTA updates. Has not happened again since. Everything functions as expected in my Bronco, and I don’t want an OTA to brick my ride.
RobWTX
Having OTA on is like us all being Guinea pigs for Ford, I always turn that crap off. If I need an update, I will manually install it. Same on my phone.
CaseyG
Casey
Bethlehem PA
Infiniti
I’ve searched thru the forum but didn’t find a post with this particular issue. We have a 2024 black diamond with mid package & sometimes when we start the car the screen just has the large Bronco logo & it is unresponsive. It will stay like that for about a minute & then restart itself & finally loads up. Restarting the car forces the infotainment to work again. Has anyone else had this issue & do you know of a resolution?
I have a 2022 Black Diamond mid package as well. I have the same issue. I have not found a way to fix the problem. Of course it doesn’t happen when I go to the dealer so I just video when it happens and I’ll bring it in when I have a few more.
clintontx
clintontx
Clinton
TX
Ford F-250
Dealership was unable to reproduce the issue & said all software is up to date. No resolution which is no surprise.
AreUgettingEnufCaffeine
JD
Ohio
2023 Bronco 2 Door
I'm going to keep putting up with the issues, But the day it leaves me on the side of the road, That'll be it for me
