Never noticed that. Have to try it, nice...It opens and holds at 45, 90 and 120 degrees. Under 45 and there is closing pressure on the strut. In between the other positions, there is opening pressure. Beautiful!
That's ridiculously funny!!! I haven't touched my visors yet.Haha agreed! It’s not like it’s that serious and it’s totally the shortness of the window. I guess as long as you get your “Cali lean on” to see underneath them, they’re just fine. If I can’t think of anything else for my list, it’s a good problem to have.
the seat belt warning is annoying, you'd think the truck would know that nobody is sitting there anymore and clear it by itself, but it won't. Have to hit "ok" on the wheel. I'll see about disabling that.Whenever I drop my kids off at school and they get out, it sets off the seatbelt alarm. Also if one of them puts their backpack in the middle of the backseat it sets off the seatbelt alarm.
The remote start turns on the rear defroster even though it it is a soft top.
Agree... plus when linked to the truck and using Waze it overheats and stops charging.I'll start by saying I LOVE my Bronco. The only real complaint I'd have so far is the wireless charger for the phone in the Lux Package. As expected, the phone slides around in the compartment and so it doesn't charge. It's been a completely useless feature for me.
Have you tried hitting the door lock button on the key fob immediately before hitting the remote start button? I couldn't get mine to work until I started doing that. My other cars the remote start button would also lock the doors automatically as part of starting.I got my Bronco last week. The app allows me to remote start, but my key fobs don't anymore. Every once in a while it will flash a light as it's trying, but it won't start from the fobs. They even blink red showing there's an error.
For me it stops charging bcuz it gets hot.I have noticed that even if it doesn't even move the charging will stop. Have no idea why. I even did a little experiment in the garage. It started charging and in a bit just stopped.
That’s Ford’s brand-wide remote start procedure, 1 x lock then 2 x remote start button on the fob. Everyone does it slightly different it seems.Have you tried hitting the door lock button on the key fob immediately before hitting the remote start button? I couldn't get mine to work until I started doing that. My other cars the remote start button would also lock the doors automatically as part of starting.
Oh, is that what that button does? I was pushing it over and over trying to figure out what it does.Don't you have a cabin light on the rear roll bar cross member? I accidently found that I had to turn it on with a button in the above console by the front row overhead light buttons.
That Worked!! Thank you!Have you tried hitting the door lock button on the key fob immediately before hitting the remote start button? I couldn't get mine to work until I started doing that. My other cars the remote start button would also lock the doors automatically as part of starting.
I also found out the hard way. Remote start from the FOB doesn't work unless you double click the lock button and hear the horn first. Never saw that mentioned anywhere, not even in the manual.Have you tried hitting the door lock button on the key fob immediately before hitting the remote start button? I couldn't get mine to work until I started doing that. My other cars the remote start button would also lock the doors automatically as part of starting.
Must. Get. Bigger. Tires.
Actually, I think the idea is to provide better sun protection when the visor is used on the side windows. Just angle the visor where you need it for the front instead of having it vertical. YMMVThat's ridiculously funny!!! I haven't touched my visors yet.
True, and that's in the plan once they're back in stock. Regardless, if you're on 33s or 37s these crossmembers are the first thing to hit as you break over step obstacles with the front tires.Must. Get. Bigger. Tires.
Oh that's weird that they swapped the controls! Yeah, mine is an '18.2015-2017 Mustang audio controls were on the right, 2018+ are on the left. This took some getting used to when I got my 2020 after owning a 2017.
You can either take the key out of your pocket.Don’t have a Ford to try it yet, but on my GM vehicles with the fob if you leave the driver’s door open it won’t do the double honk…must think you are coming right back. Not ideal if it raining or very cold, but it prevents the honk of the horn. Might be worth a try on the Bronco.
