"Budget" 4 Door Badlands-Sasquatch Configuration - Using Survey Pricing
BuckeyeinNV
Matt
Henderson NV
4Runner
Don't listen to people telling you to skip the Squatch if you want 35s. If you want 35s, get them from the factory. It will be better in the long run.
aabsalon
Alan
Sacramento
Toyota Tacoma
Seems short sighted to skip mid package
Spending 50k and not getting auto climate control, no intelligent access, and most of the other features people expect on a 30k car
Sacramento is hot as hell and miserable all summer, ain't nobody driving around too off when it's 108.
Seems like you are trying to buy on a budget which is respectable but you're also buying about the most expensive bronco possible.....
While you are at it, add the motor too
What is the difference between intelligent access with push button start and remote keyless access with push button start?
The standard package comes with air conditioning, power windows/locks, and apple carplay/android auto. That is fine with me.
Straight 6
Brad
Ca
BMW
The ability to lock and unlock doors or the rear gate by touching the handle with the key still in your pocket is the intelligent bit. It may sound silly but once you have it you wonder how you got by without it
The standard ac will have the hot to cold dial, the fan dial and the air direction settings. The auto just lets you pick a temp and never have to mess with it. The "dual zone" is pretty much a lie, but the auto temp control is critical IMO
So on a hot day, you just get in the car. You don't crank the AC and then have to turn it down as it catches up, it's all done for you
GotGOAT
Tim
PA
Dodge Ram
Based on your preference for no electronic stuff, depending on your budget I would look at Base + Sasquatch + 2.7/auto. The Sasquatch gives you the same suspension as the BL with 10mm (less than a half an inch) less travel. You lose the Sway Bar Disconnect but you save thousands and you can add a manual sway bar disconnect from the aftermarket.
aabsalon
Alan
Sacramento
Toyota Tacoma
How do manual sway bar disconnects work?
