- Reg
- Feb 19, 2023
- 2
- 6
- 2
- Austin Texas
- Bronco
- Base
Hello Everyone,
I have a 2-door Base and in the process of installing a brake controller for a DIY Tow Package.
I have used the Curt 4-pin wiring harness and converted it to a 4/7 pin connector. I have wired the 4 pins to their corresponding pins in the 7-pin version, and that left me with 3 pins which are:
Before i learned about Curt Echo, i was going to use this brake controller: https://accessories.ford.com/products/bronco-2021-trailer-brake-controller-towing-pack-1
I understand that to install a wired Brake Controller, i have to drill a hole for the adjuster button of the BC, connect the BC to the wiring harness under the dash, then splice the blue wire from the 7-pin to the blue wire of this wiring harness.
It makes sense that the blue wire connection from the 7pin will be connected to the blue wire of the wiring harness under the dash for the Bluetooth (Curt Echo) version as well . I am unable to find any confirmation for this anywhere so asking here in case anyone knows.
Thank you in advance.
- red - 12V+ AUX Charging which i plan to connect to an ignition enabled 12V
- blue - trailer brake which connects to the brake controller
- purple - reverse light (i don't plan to connect this to anything for now)
