Can I put my Sasquatch tires (Goodyear 35s) onto the stock Badlands 17x8 wheels?
JohnnyMotorBoat
Austin, TX
Ford Bronco Wildtrak 2 Door
I'm considering buying some Badlands wheels because I like the look of them better than the ones that came on my Wildtrak/Squatch. Would there be any problem moving over the Goodyear 35s onto the Badlands wheels?
Seems like 17x8 vs 17x8.5 is pretty minimal difference. @Discount Tire or someone with the knowledge, advice is greatly appreciated!
Ford Bronco Can I put my Sasquatch tires (Goodyear 35s) onto the stock Badlands 17x8 wheels? Wildtrak_Badlands_Compare.JPG
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Get yourself a wheel spacer somewhere in the range of 1" - 1.5" in width, otherwise you'll most likely rub.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
@JohnnyMotorBoat 35's are an acceptable fitment on the 17X8 wheel.
The high offset wheel will most likely rub and needs to be spaced out.
KABQ
Aaron
Albuquerque, NM
They should fit.
I'm still trying to figure out how to fit this 37" on my Harley :p
Ford Bronco Can I put my Sasquatch tires (Goodyear 35s) onto the stock Badlands 17x8 wheels? 0308231743_HDR~2
With a sawzall and a welder you can do ANYTHING
