clicking, mechanical noise footwell area.. video is me in a parking lot going in normal circles not tight circles
  • Thread starter Deleted member 41389
  • Start date
  • Watchers 4
Guest
turning into parking lots,, turning in circles,, 2wd... also makes a similar noise sometimes when opening the vehicle to get in, not running,, sounds like it's behind the footwell possibly,, have already checked everything under for anything being loose.. anyone experienced and had a answer ?
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
Sounds like ABS module activating. Not sure why it would be? Turn Traction Control OFF and do the same thing and see if it still does it.
2.3L or 2.7L? They have different brake systems, so it might make a difference.
Guest
2.7,,, gonna turn traction off now and go try
Guest
traction turned off,, taking a left onto a side street...
22 model 2 door 2.7 with 199 miles
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Since it makes the sound while turning and when getting into the vehicle when off, check your body bushings, the bolt that goes trhough them.
Guest
doesn't make any sound gettin into the vehicle,. just when you open the door,, like a control module or something clicking.. the sound at the footwell when turning sounds like a module , two pieces of thin metal clinging together, and electric noise all in one ..
MayhemMike
Mercury
Mine makes a slight noise when getting in. Sounds like circuits are energizing in anticipation of the vehicle being started up. Not a loud noise but a subtle noise that stands out to an old timer.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Gotcha.
flip
Phil
IN
www.ruxerparts.com
Fords
DM me your VIN. Would like to look at your VHR but that's not normal.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, Derrick. Will you send us a message with your VIN and dealership info? I can look into your vehicle concern on my end.
AntGar55
Anthony
Fullerton CA
2022 Ford Bronco
Hey guys. I am experiencing this same noise in my 2022 - 2DR - 2.7. Have any remedies been discovered? My dealership can’t figure it out. Thanks!
AntGar55
Anthony
Fullerton CA
2022 Ford Bronco
Hello FMC. I am experiencing the same issue and my dealership can’t figure out the noise. Can you check my VIN please? 1FMDE5AP6NLA76349. Thank You.
Daxe44
Dax
Tampa
22 Ford Bronco
Did anyone get a resolution to this issue? I have the same problem and was reading about using ForScan to update the software to accommodate larger tires and relearning the ABS module etc. any help appreciated
AntGar55
Anthony
Fullerton CA
2022 Ford Bronco
My dealership said it’s normal due to weight distribution when making a U Turn over bumps or downhill U Turn. They are ordering a clock spring part to try remedy but it’s on back order. This noise is not a normal noise for new vehicle with 19K miles.
