Cold temp camera not working
Bobio
Bobby
United States
2024 Bad lands
Ford Bronco Cold temp camera not working IMG_3252
Ford Bronco Cold temp camera not working IMG_3251
When the temp his below 45 I get this, and they won’t work and also my cruise control stops working, lol almost forgot so does my auto brights doesn’t work either. I took it to the dealership and they said it sounded like a cold cranking amps not up to snuff. They tested and replaced my battery but started up again on the first 44 morning. I’m thinking when I installed my 3 lights in the grill maybe I screwed up the front camera. But it’s weird it only does it at cold temps. Have anyone of you seen this before?
Ford Bronco Cold temp camera not working IMG_3351
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
It’s not your battery, and it sounds like something upstream, perhaps a module.
The camera behind the windshield is responsible for PCB as well as auto high beams.
Have you had your glass replaced recently?
Bobio
Bobby
United States
2024 Bad lands
No. It’s only 8 months old and after reading stuff trying to fiq it out I did read that it’s in front of the mirror but the warning on my iPhone app says to try to clean grill next to camera but I’m with you about it being up on the windshield. The dealership said if that battery change didn’t work they’ll have to go in for longer diagnostic for a few weeks waiting list. Fuuuuudge. It started the very first overnight at a hotel room and sitting outside for the first time. it got down to 20 and serious frost. And now every time it gets under 44 it shuts off.
tclem3314
Trace
2024Bronco!
2024 Bronco 4d
Getting the same error on my 24 Wildtrak with 700 miles. Mine is typically below 30 degrees. Haven’t really had time to investigate, not wanting to take to dealership due to horrible customer service and techs with no experience.
Curious on what you find to be the fix.
