3M makes miles of that tape everyday. Use some fishing line and a heat gun. Heated a bit, then just like using dental floss ( I am taking for granted you are familiar with dental hygiene tools) pull the line back and forth while moving through the back of the name plate. BTW, anytime you want to stick one of these sort of things on to a vehicle or such, only remove small parts of the tape backing. Leave the backing removed hanging off the tape. You can then set the name plate into the position you like , and once there hold the plate with some pressure and then pull the tape tags off the rest of the way. Having only a couple of small attaching points makes it way easier to adjust.
