Curb rash question?
joshgonztx
Joshua
Dallas
I just installed new tires and I just noticed one wheel had curb rash, I sure it wasn’t there before. And I noticed it the next morning. It had some black gunk covering it up and I wiped it away.
my question is can a machine at a tire shop cause it?
it’s kinda high up where it is and here the curbs are only a few inches tall.
Ford Bronco Curb rash question? 4007F072-6497-4975-8C68-46F0737FF786
thesocalexplorer
Southern California
Wow that's definitely pretty high up on the wheel. I've had wheels scratched by tire installation before, but it was less of a "coarse" type scratch like above, and more of a smooth line/series of a few lines. Usually down by the lip also.
joshgonztx
joshgonztx
Joshua
Dallas
Yeah it looks very high up. Now to try to buff it out.
Gizmo
Randy
Grand Rapids Mi
2020 Alfa Romeo Stelvio 2020 Porsche Macan 23 OBX
i had something similar happen to a few cars from the car wash, and had to have the rims repaired.
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
Wow, sorry that happened. Unfortunately I think it happens more than you think- it has happened to me more than a few times- my wheels scratched, paint scraped off, etc. More on low profile tires and wheels as I am told they are more difficult to mount. Not everyone who operates tire equipment is careful. It depends on how experienced they are and the training they received. It's sometimes hard to find a really good tire shop. About 6 months ago I had tires mounted on my brand new C6 Corvette wheels. I always take the tires and wheels off myself and have them mounted/balanced to lessen the risk of any more issues or over tightening, etc. Anyway, I did not notice until I got home the scrapes right at the edge of the wheel.​
It can be repaired and you can do it yourself if you are patient and detailed......I repaired my C6 wheels and many others. You first have to file/sand, blend to get the major grooves out. Then sand more with finer and finer grades up until like an 800 or 1000 with wet sand paper. Make sure the sanding is well blended in with the surrounding painted area. Mask, then spray a light coat of primer, let dry, then coat with matching paint if possible. If not, find something as close as possible. After painting and the paint is thoroughly dry, wet sand again, then spray clear coat. Then buff with an electric drill with the foam pads and clear coat mild polish. The key is to blend it all in. Is it time consuming- yes. You have to have patience. The key is the sanding and blending an buffing after- not the paint application. You can actually brush the paint on, just required more sanding.​
joshgonztx
joshgonztx
Joshua
Dallas
Thanks for being detailed, going to try it next week.
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
I work in auto service. Never seen a tire machine scratch a wheel like that. 99% sure thats rubbed a curb or something. Youll need some serious tools to smooth a polish that out. Last dealer I worked for did those repairs. Had $40k lathe specifically for it. We charged $150-200 per wheel to repair them. Id call around and see if you can find a shop that does that kind of repair.
Moto26
Tucson AZ
Agree, no way the tire machine did that. This is not to say, however, the people working on the vehicle didn't do the damage some other way. Definitely looks like curb damage. If you're sure you didn't curb the thing somewhere, it's probable they did it while moving the Bronco around...
I used to co-own a motorcycle shop, and we had a customer come in raging, the day after we put a new rear tire on for him. He swore up and down we damaged his rim. Well, the wheel had a big ol' deflection in the rim, and we had to demonstrate how our tire machine worked for him, to show it was physically impossible for our machine to do that.
He finally calmed down, and after thinking back over the previous 24 hours he realized that he did, in fact, run over a rather large pothole on the way home! 🤦‍♂️
TXBronco1313
Did your wife/girlfriend take it for a spin recently?
Shanine
Shanine
Ford Bronco
Dealing with curb rash on your wheels can be such a headache, right? you check out Lil' Bubba's curb machine! It's a game-changer! Not only does it help you create beautiful custom curbs, but it also saves you from the hassle of dealing with those pesky curb scratches. You cannot worry how much is a lil bubba curb machine coz it will be worth it!
GRB1959
Gordon
Aurora, CO
2021 Ford Edge ST, 2024 Ford Bronco Badlands
In August of 2022 my wife's 2021 Ford Edge ST sustained curb rash. I found a local wheel refinishing shop in Denver, CO, and they charged $150 to remove the scratches and refinish the wheel. It looks brand new after they completed their work.
Here is the local shop that I used.
https://www.awrswheelrepair.com/location/Aurora/80016/
They do charge a bit more if they have to remove the tire from the wheel. In this case I took only the damaged wheel into their shop so I got the $150 per wheel rate.
24BDSAS2DR2.7
Leonardtown, Maryland
1955 TBird, 1971 GTO, 2004 Chopper, 2016 Indian
Did the service tech drive it while you were waiting?
