I want to add some decals such as a hockey stripe. My main concern is that in a few years it may look like crap. Then if I remove it, wouldn’t my paint look different than the surrounding Paint??
It will only look bad if you don't refresh it. There are very few things you can have on the exterior of a vehicle that doesn't require maintenance.I want to add some decals such as a hockey stripe. My main concern is that in a few years it may look like crap. Then if I remove it, wouldn’t my paint look different than the surrounding Paint??
I think the four door, needs graphics to break up all that paint, where a 2 door doesn't. I was thinking about going with the same style as your's, start small and if a refresh is needed, you can go bigger. Start with Hockey stripe's, and after 4 years one may have to stick with them for life.I put stripe decals on mine and love the look. I also did it knowing I’d likely need to “refresh” it years down the road and I’m ok with that.
If you think you’ll like the look of the decals years from now I say go for it. I think it really completes the look I was going for.
Nothing a little Goo-Gone® followed by isopropyl alcohol won't take off.I think the four door, needs graphics to break up all that paint, where a 2 door doesn't. I was thinking about going with the same style as your's, start small and if a refresh is needed, you can go bigger. Start with Hockey stripe's, and after 4 years one may have to stick with them for life.
Anyone know how difficult it is to remove graphics, a year down the road?
With a heat gun, they come off very easily. A hairdryer also does the trick.I think the four door, needs graphics to break up all that paint, where a 2 door doesn't. I was thinking about going with the same style as your's, start small and if a refresh is needed, you can go bigger. Start with Hockey stripe's, and after 4 years one may have to stick with them for life.
If you take care of your vehicle it won't look like crap.I want to add some decals such as a hockey stripe. My main concern is that in a few years it may look like crap. Then if I remove it, wouldn’t my paint look different than the surrounding Paint??
