Different Engine Sound in 2.7L - Badlands vs Wildtrak
Sixtysixpride
Zach
Mi
Ranger
The only difference >> the OP wanted a Wildtrak instead of a Badlands and thus subconsciously made up what he was hearing.
If the Wildtrak was such the cats mammaries they would have based the Raptor and Heritage Limited on those instead of the Badlands 🥱
JohnZi
JohnZi
Piotr
British Columbia, Canada
www.instagram.com
Bronco Badlands '21
Doesn't one have carpeting and the other rubber flooring? I've heard a few people mention that it makes a difference in the outside cabin noise between the two as well. Probably does the same for exhaust sounds.
Hmm both have carpets.
Also as I mentioned, we were both using Normal mode for that comparison test.
The only thing I am not sure of is if the other car has LUX package. Maybe that would be it. Definitely, it's something going on there and maybe we will get some answers in the future.
Thanks for the replies!
JohnZi
JohnZi
Piotr
www.instagram.com
Bronco Badlands '21
Do both/either have the high package? High package has extra sound deadening under the hood and at the firewall.
I have the high package for sure and I have sound deadening under the hood. I need to check with the other car though, as I am not sure what's his trim.
In your Wildtrak, do you have the under hood sound deadening? How is your engine sound?
brentutk
Brent
Nashville, TN
Eruption Green Wildtrak
Yea I have a Wildtrak with the high package. My engine sounds "fine" but I've never had an opportunity to compare to a Badlands. I've had 2 Wildtrak's with similar engine feel.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Badlands most certainly doesn’t have carpet floors.
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
There is additional sound deadening with the high and LUX packages. That could be difference you hear.
Aman
Aman
Northern NJ
It has carpeting if you choose leather seats. The wash out flooring only comes with MGV.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
So at some point, I owned two Broncos. "Both were badlands but one was with the High package, the other was the Lux package. I did notice that the Lux Bronco sounded a whole lot better than the High Bronco. The High sounded more flat and quiet, the Lux sounded more sporty, throaty, deeper and I loved it.
BroncoWyo
Wyoming
2022 Ford Bronco 2 dr
Interesting because there is a noticeable difference in engine noise/tone when I shift my 2.3L 7MT Badlands from Normal to Sport mode. It sounds waaaay more aggressive with my driving style the same. AFAIK the Bronco doesn't have any sort of active exhaust either.
Kind of off topic, but you have Sport mode? I have a 2.3L MT Badlands as well and it doesn't have sport mode. I have read that you can use Baja mode and shift to 2H to get the same affect.
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Yeah I used Forscan to add it. Haven't tried Baja to verify if its the same or not.
JohnZi
JohnZi
Piotr
www.instagram.com
Bronco Badlands '21
Yeah I chose leather seats so I have carpet for sure in my badlands
yeah I am afraid that might be the case. I wish I knew it before because I certainly like that deeper sound better!
no, I don't have sport mode. I used that hack with baja mode you mentioned about. It's still not the same sound I heard in Wildtrak.
