DIY - Top lift in garage
Bellime
Keith
2022 Ford Bronco
I thought I would chime in on what I came up with for a very inexpensive lift system for my OEM 4dr Rack and the three top panels. There is no reason this couldn’t be use for rear section also.
I found a this hand winch “Zostera Trailer Boat Hand Winch with Heavy-Duty Gears 1200lbs” for $36 and grabbed a bunch I-bolts, double pulleys and strong nylon cord at ACE Hardware. I removed the strap that came with the winch. Screwed the I-bolts into the joist behind the sheet rock. The rest is a lot threading of line.
Ford Bronco DIY - Top lift in garage IMG_1821
mmorgan
South Carolina
GMC JImmy
Interesting but better photos and more details would make it more so.
