Does anyone know if the factory rocksliders/side steps that come on the raptor fit the standard 4 door bronco? Looking to acquire a set if so.
have you checked out Archetype Magnums? Not identical but a good looking slider mount alternative option.I was hoping the sliders matched up and we could just bolt those in. Haven’t Seen anything on it yet
I don't think they do. If wherever your buying them from had free returns than try it!Does anyone know if the factory rocksliders/side steps that come on the raptor fit the standard 4 door bronco? Looking to acquire a set if so.
This was my same thought process. Have to imagine the mounting points are the same for the sliders. It’s just an additional Attachment to them. Really curious if anyone has taken the leap on itSince everyone else is speculating I’ll add my thoughts. I bet they fit just fine. The door and body panels in that area that the sliders attach to (and most, if not all, other areas) appear to be the same on all Broncos and this thought is supported by the fact it wouldn’t make sense for Ford to retool those parts at the cost of literally 10’s of millions of dollars for new tools for a fairly small run of Bronco Raptors. This belief is based on a long manufacturing career, of which I spent the last 8 years signing off on tool capital requests for new products and alterations to existing tools.
The only body panels I know to be different are the gills on the front fenders and the hood and those alterations are likely accomplished by second op’s tools of processes.
You assume a "fairly small run." I believe Ford intends to run the Raptors at volume capacity, or slightly under to maintain artificial scarcity. It's not like they've only made a handful of F-150 Raptors, which have a lot of unique tooling vs the regular F-150s.Since everyone else is speculating I’ll add my thoughts. I bet they fit just fine. The door and body panels in that area that the sliders attach to (and most, if not all, other areas) appear to be the same on all Broncos and this thought is supported by the fact it wouldn’t make sense for Ford to retool those parts at the cost of literally 10’s of millions of dollars for new tools for a fairly small run of Bronco Raptors. This belief is based on a long manufacturing career, of which I spent the last 8 years signing off on tool capital requests for new products and alterations to existing tools.
I added the IAG steps (not full length) on mine. I used some neoprene and stainless washers to prevent the pinch screws from biting into my rock rails, and some fiber washers to keep the serrated nut from damaging the powder coat on the steps. The only exposed steel is in the thread holes on the IAG steps. The blue locktite will keep everything together.The IAG's add a step is the only thing I've found that slides on the existing Non-Raptor Rail. The more I weighed the ease of installation vs the ability of a slide-on option to hold any vehicle weight, I changed direction. I really like the look, but a few pinch screws in a snow (brine) area seemed like a bad idea.
I'm shocked Ford didn't just put the Raptor rails on all units to save another part to develop.
ask the folks over at doetsch offroad, they just removed some raptor factory sliders to install the RSE stepsDoes anyone know if the factory rocksliders/side steps that come on the raptor fit the standard 4 door bronco? Looking to acquire a set if so.
