Does Anything Work With OEM Rack?
lni
Lni
Seattle
2Dr Badsquatch, Porsche GT4, BMW M3
I've been looking for side racks (over side rear window on hard top) that mount to OEM roof rack. Is there such a thing? It seems there's only options to mount another rack on top of the OEM rack.
I'm trying so hard to still get into those 6' 6" parking garages and still use the thing for what I want on trails, and hoped a side mount system would work best... Anybody know of anything like that? Molle or otherwise?
5280Bronco
Denver
I have not been able to find any, but maybe someone out there knows something we don't know.
lni
Lni
Seattle
I am keeping my eye on these. I will have the OEM rack also and would like to keep it if possible. Unsure if this will fit the Bronco OEM but Im hoping to find something like this.
Same, and tht one is kind of what I was hoping existed for our OEM rack - That one doesn't look like it would work unless you want to drill into the rails, and I'd rather have something that doesn't require modifications
adamruiz2001
SoCal
Ford SVT Lightning
Came across this, not sure if this is what you were looking for
https://badasstents.com/product/2021-22-ford-bronco-rotopax-mounting-bracket-plate-kit/
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
I went back and forth with the OEM Rack and while I could install my 80lb tent and 30lb awning I would of had to make special brackets to mount the awning and decided if I'm dumping any money into the OEM rack to use it, I would just put that money towards an aftermarket rack that increased my dynamic weight limits and allowed me to carry more stuff easily. This is really important in the 2-door. After a few months I ended up getting the TrailRax roof rack and their PaxRax side mounts and it has made it so much easier to mount everything and more stuff to my Bronco. Unfortunately the BaddAss Tent option doesn't work on the 2-door and even with the 4-door I don't think you can really carry anything with it beyond rotopax's.
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
I agree, I’d like to see brackets that mount to the roof rack side rails (the ones that run the length front/back of the bronco), brackets for paddles, fishing rods etc. everything mounts to the cross rails.
nwGTS
Nate
Chicago, IL
Raising my hand for this same solution hoping some manufacturer sees it. I want to mount recovery boards and fuel to the side so I can get in my 7 foot garage.
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
2021 Bronco 4 door Outer Banks, Kia soul 4u
Does the awning not mount directly to the OEM racks?
emulous74
Seth
Only way I was able to make it work, since the OEM Bars do not have t-slots is to use a u-bolt that goes under, or improvise one like the RTT's mount. This requires an awning mount that is L-shaped and wider than the OEM bars. You just have to get creative. I've seen people basically wrap the side rails with rubber mounts, but that doesn't seem safe to me.
emulous74
Seth
How about using large Quick Fists? You could mount them with revnuts, if you want to drill a hole into the side bars?
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
Thanks for the info! Now I can plan out my purchase and I now have an idea of what to expect. I wasn't sure exactly how it would go, so I thought I'd do some digging but there isn't much info available so thank you👊
MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
I think I can visualize what you did, but could you post some pictures? Thanks.
emulous74
Seth
I snapped this one from the internet. I've done what I said on my trailer, but it is at my other house, so I'll take pictures of what I did exactly, tomorrow.
Ford Bronco Does Anything Work With OEM Rack? fbe62e9450a2e8a1a0f381cb28cf9b61
MoabRox
Great. Thanks!
