Driver Error?
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
Yikes. Looks like only way to get it to the road is dragging it backwards down the trail. Driver looking back and tires tracks going backwards.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
All joking aside. I’m glad this didn’t happen on the freeway at 80 mph. I personally had a mishap Saturday when my pipe wrench broke and we dropped my well pipe. No one got hurt and assume no one riding in the bronco got hurt either. Hard lesson learned. We got ahead of ourselves and I see people doing the same with their builds.
texasgreazer
Burleson TX
2020 Explorer, 2019 GMC Canyon
looks like the tie rods are just dangling from the spindles... like they were not properly tightened after the alignment from adding the tires... they vibrated loose and then catastrophic failure... i doubt this will be covered by warranty...
My brother-in-law had lift/tires/wheels and brakes done on his F150. About a month later, he heard a loud noise from the rear, followed by a blowout. Apparently the shop either didn't install the bolts in the caliper, or they came lose and vibrated completely out. Caliper came off the disc and hit the tire causing the blowout. Only thing holding onto the truck was the hose.
edgeflyer
2013 FX4
You can see the threads on the driver's side outer tie rod end. Passenger side is harder to tell, but it looks like someone parked it and unscrewed the tierods for a conviently distant picture. I see nothing broken. 2+2=6 here.
BroncoAgain
La Verne, Calif
2022 Gladiator Rubicon, Ram 2500 6.7 4x4
As people get these things modded and take them out to bounce them we are going to see more pictures like this. Good luck with the warranty.
JimL
Pittsburgh PA
2019 Bullitt, 2020 Ford F-150
Seriously, I'd be interested to hear exactly how this happened. This really hurts to look at.
WadeWolf76
Damon
Kansas
15 Wrangler JK Willy's, 67 Ford Mustang coupe
This right here is why you never apply tire shine. This is what happens.
xcxv
hmm
Jeep Bronco
Lol. looks like aftermarket lift, wheels and tires. no warranty.
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Since you mentioned this. I have not seen any steering link upgrades.
Just upper a arms, rear track bars, and lifts (coil or spacer)
I would love to have 37’s, but I will wait for the right upgrade and 6 years once it’s paid off.
Camburg and RPG have them.
MaverickMan
Shane
ratchet straps and a piece of pipe or a couple tree branches should do the trick. Wont drive but could to to the road. I would go backwards so the side loads are put on the rear axle while turning.
