EDIT (fixed) Anyone notice poor hood alignment?
Oh yea Bronco!
Amber
Ferndale, MI
10/21/214dr BB, 2.7, A51. & ā€˜90 Wrangler V6 MT 4.2
Under the hood there are 2 black rubber pads on threads you can twist them up or down. They are near the corners by grille
Will be trying this soon. Thanks for posting this info!
BigIrish
Ryan
Lincoln Continental
My hood sits slightly lower than fender top edge of both sides equally. Visible from drivers seat but others on here have said ot is normal
same mine sits slightly lower
Lake Tahoe Traveler
Sf Bay Area, CA
2022 Bronco 2dr BL SASQ, & 1975 Bronco Ranger
I’ve alredy addressed the issues with my service department but thought I’d ask to see if anyone has noticed crazy bad gaps in the hood/fender area?
You can really see it on the pictures below there’s an almost 1/4ā€ ā€œdipā€ in the middle of the hood on the passenger side where it meets the fender. Also from head on there’s a gap big enough to fit my index finger (again passenger side) between the grill and hood. It’s like a 1/8ā€ on the driver side?
My truck has a barely noticeable dip right behind the drivers front marker.
At the Off Roadeo I took notice to the hood gaps … they were all high… evidently the fender higher than the hood is normal…
so I readjusted my hood back!!!
I have come to accept my truck with these factory defects….
I’m pretty much ashamed of myself…
I just can’t chase my tail anymore
Oh yea Bronco!
Amber
Ferndale, MI
did this work for you?
One side is still higher than the other and I didn’t notice much of a difference but I only tinkered with it once. It’s been too cold here in MI to keep doing it since it seems to require trial and error. I notice it every time I drive. It’ll likely be the first thing I do come spring.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I have a very very similar issue. Same spot but on the drivers side.
I decided to forgo having the dealership do anything - figured their body shop would make it worse (alum hood) or a replacement and repaint would not match
Same here. I bet a body shop could tap it straight. I'll see if the dealer can send it over to them while my 2.7 is out for replacement in about 800 miles :geek:
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? PXL_20220131_042537290
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
Warped hoods are a known warranty issue!
You should by all rights get a brand new painted hood from Ford!
Gamecock2010
Thomas
Charleston, South Carolina
2016 Mazda CX-9
same here. there are some adjustments you can make to the posts the front of the hood rests on, but even with mine adjusted it sits a little low. My dealer showed me that it was also that way on their two demo trucks.
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
Post edited above!
Problem resolved!
Mookichuk
Chuck
New York
I have the same exact issue. Did you dealer ever do anything to resolve?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I never bothered reporting that bow or the crapiness of the hard top and ultimately sold it instead after seeing Ford decline to fix so many "cosmetic" issues here. I wish you good luck!
Erad419
2023 Badsquatch
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? IMG_1631
I just took delivery of my new 2023 Badsquatch today. Opened the hood to look at the engine and the hood wouldn’t shut! That’s when I noticed the hood was terribly misaligned (see pic). Just dropped it off at the dealership to get fixed. Makes me glad I bought the extended warranty if this is a sign of things to come. Yikes.
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
In my case it was actually a warped hood and they replaced it with a new one.
